disable closed loop on the $8d
Old Dec 28, 2008 | 11:03 PM
91350rs's Avatar
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
ive decided to tune and stay in open loop after tuning, problem is i dont know which settings to modify to make sure closed loop is never enabled.
I know I need to set the temperature to some way off high number like 999*C, but there are three different closed loop temp settings that can be adjusted and I need to know which ones to change to ENSURE closed loop stays non-active
Loop Closed Enable Hot Temp. Threshold
Loop Closed Enable Min. Temp
Loop Closed Timer Cold Temp. Threshold
I have already changed the "Loop Closed Enable Min. Temp" to 999*C, do i need to change the other two as well, and is this all that needs to be done to ensure closed loop is never enabled?
thanks
Old Dec 29, 2008 | 12:03 AM
redbird92''s Avatar
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
Re: disable closed loop on the $8d
you should be fine with what you have done.
rhead007's Avatar
Car: 73LT,81Z,85Z
Engine: 350 350 350
Transmission: 700r4 700r4 700r4
what two wires are ya closing the maf sensor what colors i got four wires and dont know witch two to jump so its closed
Old Dec 29, 2008 | 12:08 AM
91350rs's Avatar
Car: 91 camaro RS
Transmission: t56
Axle/Gears: 4.10
Old Dec 29, 2008 | 12:48 AM
redbird92''s Avatar
Car: 92' firebird
A little off base we are talking about prom tuning not re-wiring
Old Jan 23, 2009 | 11:36 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
sometimee i tipe wit my face two butt it dont werk out two gud.
Exactly what i would have suggested to you.
Old Jan 25, 2009 | 10:12 AM
rhead007's Avatar
Car: 73LT,81Z,85Z
Engine: 350 350 350
so you can only do this with the prom i cant jump wires to temerarly till i get one
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
