noid light question and i cooked my ecm?
Old Mar 17, 2009 | 08:12 PM
haha27's Avatar
From: springfield. aka springtucky.aka.the dirtyfield ohio
Car: 85.iroc.z28
Engine: 385 tpi
hey all my car started and ran good but at about 2500 rpm it had a slight shake thinkin it might be a bad injector connection witch has happned to me before i hooked up my noid light with engine at idle the light stayed solid is this right? this was on cyl #8.
so after a while still toying with the car both wires pulled out of the connector and touched the fuel rail---zap--- engine died.
started car back up and ran like ****. now the right bank of injectors my noid light dont work all did i just cook the driver in my ecm? and did it hurt the chip? also i think my ecm has bein messin up cause every time i turn the key on the coolant fan runs all the time..
please help
Old Mar 17, 2009 | 10:17 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
Re: noid light question and i cooked my ecm?
Check for a blown injector fuse. there is one for each bank. good luck
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
