NO SPARK SUDDENLY 1987 2.8 V6
Hiya people, I have only had my 87 2.8 V6 3rd Gen a week and shes broken down on me, she has recently had an engine rebuild and was running great until 3 days ago when I wen to start her after 20 minutes and there is no spark..... ive fiddled with everything and still no spark, had distributer cap off and cleaned and check all the usual things, checked wiring, chcked all fuses and even swapped the coilpack for another.... and still no spark, I am desperate for any help or pointers as to what it could be, the car was fine 1 minute then just no spark 20 minutes later.
please please please help me lol
thanks,
Dan.
thanks,
Dan.
Car: check
Engine: check
Transmission: check
Re: NO SPARK SUDDENLY 1987 2.8 V6
Ninety-percent of the time this is caused by a dead ignition module. The other ten-percent of the time it is caused by a bad pickup coil. Both of these are in the distributor.
Of course it always pays to check the simple stuff first. Such as +12 volts to the coil. This is the heavy pink wire at the coil connector.
If it is the ignition module best to use a GM part. The others just are not as good.
RBob.
RBob.
Thankyou very much for your reply, I hd it all aart today and my mate wagged the ignition module at me and said it could be this but I didnt even know what it was ! do you know of anywhere online in UK I an get a GM ignition module and full distributer kit from ?
thanks again,
Dan.
thanks again,
Dan.
Car: check
Engine: check
Transmission: check
thanks again,
Dan.
thanks again,
Dan.
RBob.
OK thanks, ive been looking online and i think ill be able to get 1 over here ! I just dont understand ho the car was running fine then the engine was turned off then it just wouldnt spark again, whatever has blown must have blown as the key was turned to try and restart it !
Dan
Dan
