non starter
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
non starter
I have an 87 IROC I'm trying to get on the road. Its a 5.0l TUNED PORT. It has fuel pressure at the lines to the engine underhood, but the car has pressure at the rail under the plenum. I have a code 12...it tells me a code 12 can stop the engine from running. Am reading the entire service manual and have not found any way to diagnose...thoughts?
Car: check
Engine: check
Transmission: check
Re: non starter
Code 12 on a non-running engine is normal, and should happen.
During cranking do the injectors fire? Is there spark?
RBob.
RBob.
Gunner242
Dec 25, 2015 04:49 PM
