90-92 TPI stock rev limiter setting
Old Jul 9, 2009 | 12:18 AM
transam92conv's Avatar
I have a 92 TA 305 TPI conv 5spd. The original AXXC-3067 PROM was improperly reprogrammed (long story), so I replaced it with AC Delco 16163066, which is coded AXXC-3066.
Anyhow, I could've sworn I remember the original 3067 chip had a rev limiter somewhere between 5-6K rpm. With the new chip AXXC 3066, at a stand-still i revved the motor to 6k, and no rev limiter. I am not going to rev it any higer than 6k just to see if a limiter kicks in. What's up with that? Is the rev limiter not kicking in because the car is not under load? A stock prom should have a limiter in the program right?
There's no point of ever going beyond 4500rpm with this mostly stock LB9, so i'd like to have the reassurance that there's a rev limiter in case of a mis-shift or something.
Old Jul 9, 2009 | 12:43 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: 90-92 TPI stock rev limiter setting
i don't know about the 305 TPI chip. but in the 350 TPI AUJP chip, its set around 10,000 RPM.
Old Aug 8, 2009 | 05:23 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
There actually is a point in revving past 4500 RPM in a completely stock LB9. I dropped 2 tenths of a second off my quarter mile times when I raised my shift points to be right at 5000 RPM as opposed to 4500 RPM.
Old Aug 9, 2009 | 01:25 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Yep, almost 10K RPM.
theshackle
Sep 17, 2020 08:26 AM
Grant2k
Jul 10, 2018 04:01 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
gta power
Aug 13, 2015 06:15 AM
squiggy2
Aug 9, 2015 09:30 PM
