Howto test ECM?
Old Aug 14, 2009 | 02:07 PM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
Howto test ECM?
I tried searching the forums but found nothing. The car will start only with starting fluid and than the injectors take over and it will run until it warms up and hits closed loop mode it sounds like. I have checked all the sensors and it seems to be a problem that no one knows. I can't figure it out. I tried a different ECM but the same thing happens but that ECM could be bad also for all I know.
Old Aug 15, 2009 | 08:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Howto test ECM?
Many times this is from a lack of fuel pressure. It could be that the pump is weak or the filter is clogged. It can also be caused by fuel pump relay being bad.
Connect a fuel pressure gauge and at key-on, engine-off (KOEO) the fuel pump runs for 2 seconds and builds to between 9 and 13 psi (TBI). If the pump doesn't run at KOEO then look into the pump relay circuitry.
Then while running the pump maintains that pressure. If the pressure is low then need to troubleshoot why.
RBob.
Old Aug 15, 2009 | 04:08 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Howto test ECM?
What kind of car is this?
I've had a couple now, that had VATS/PASSLOCK issues, and starting the engine on starter fluid and running it for the first 20 seconds or so off the starter fluid would then get the ECM to enable the injectors.
If you've swapped the ECM, with the same result, I'd say look elsewhere.
Old Aug 16, 2009 | 03:39 PM
robster66's Avatar
Engine: 305 T.B.I.
Re: Howto test ECM?
1992 Camaro RS 305 TBI. The computer I put in could be bad. I hear the fuel pump prime every time but the injectors will not start themselves. I will post again once I get a gauge and test fuel pressure. It is a very odd problem.
Old Aug 16, 2009 | 05:04 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
Re: Howto test ECM?
I also would suspect fuel pump/pressure.
KCG
Jun 24, 2020 04:33 AM
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
eustodp
Sep 20, 2015 05:09 PM
