ignition system
Old Aug 29, 2009 | 02:31 PM
acian21's Avatar
ignition system
so i have a 92 camaro rs v6 3.1 25th anniversary..... I have replaced ignition starter switch , starter and silonoid and my ignition control module... My car will still not turn over... my tachometer is stuck all the way on the right side and will not move and i am almost fed up with it can some one help me out...
Old Aug 29, 2009 | 03:39 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ignition system
At key-on, engine-off, does the "security" light on the dash light up and stay lit? Or does it turn off after 4 seconds or so?
If it just stays on then there is a VATs issue.
RBob.
Old Aug 29, 2009 | 10:01 PM
acian21's Avatar
Re: ignition system
sometimes it comes on and stays on then other times it wil go off
Old Aug 30, 2009 | 10:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ignition system
With the security light staying on the starter motor shouldn't crank over the engine. The VATs system disables the starter.
With hte security light going off, the starter should be able to crank over the engine. If it doesn't then there is also another issue. If a stick shift there is a switch on the clutch pedal that interrupts the starter.
If an auto there is a switch on the shifter that will interrrupt the starter.
You can also use a DVM on this switch (auto or stick) to see if power is being applied via the ignition switch.
RBob.
Old Sep 2, 2009 | 02:25 PM
acian21's Avatar
Re: ignition system
power is goin everywere so i thinks its the v.a.t.s
Old Sep 4, 2009 | 12:52 PM
acian21's Avatar
Re: ignition system
is there anyway just to take the whole vats system out and the car will still work
Old Sep 8, 2009 | 04:05 PM
acian21's Avatar
Re: ignition system
so everything has checked out no security light and everything but still wont crank i keep getting a code 46
Hotrodboba400
Dec 10, 2019 07:07 PM
MM2Robinson
Oct 1, 2017 09:16 AM
383cam
Sep 9, 2015 06:01 AM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
