New tune, wrong injector
Old Oct 9, 2009 | 09:32 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
OK. I bought a set of used injectors that were suppose to be 30#'s. But when I received them today they are 32#'s. But me being an idiot and trying to rush things. I ordered my new chip that is tuned for my setup which includes 30# injectors. So will me using 32's with my chip programed to run 30's cause any problems? I will eventually get a new chip again after I get the car on the road to get it fine tuned. But will this chip get me up and running is what I am curious about. Or did I just waste my money. Any help would be appreciated! Adam :-)
Old Oct 11, 2009 | 04:03 PM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: New tune, wrong injector
that is not a problem and you can run with this chip. 2lbs is nothing that ECM won't manage with, maybe it will be just a bit rich of petrol but that will just affect milage but will give a bir more of performance, if you want to avoid that just adjust fule pressue with about 1-2 psi
best regards
Old Oct 11, 2009 | 07:52 PM
That's what I was thinking. Just needed someone to confirm it. Thanks. Adam :-)
Old Oct 14, 2009 | 01:40 PM
my87_5spgta's Avatar
who did you use to make ur chip?
Old Oct 14, 2009 | 08:41 PM
PCMforless.com. Seems like a good place to do it. Even have a thing were they will retune it after you get it dynoed or scaned.
Anyways. Got a hold of them right before they made the chip. They change the injectors to #32's!
Old Oct 15, 2009 | 12:21 PM
Thanks glad you got that change made before it was sent out!
MustangBeater20
Oct 29, 2022 09:20 PM
Thornburg
Sep 1, 2015 03:39 AM
nuggie
Aug 25, 2015 01:27 PM
soarestransam
Aug 24, 2015 08:15 AM
ezobens
Aug 19, 2015 10:29 PM
