Want to start data logging
Old Dec 4, 2009 | 10:14 AM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
I would like to hook up my computer to the aldl on my car so i can data log what the car is doing to try and diagnose a problem. but not sure which cable i need. can someone point me in the right direction? thanks.
Old Dec 4, 2009 | 01:52 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Re: Want to start data logging
Your going to need a software program 3 or 4 out there.
I use Tuner pro RT.
Cable, Quite a few places out there to get one.
I use hardware from Moates, has everything you need to get started.
Plus he is more than willing to help you out if you need help.
I like vendors like that.
Use the (Search feature) to find all the info you need.
Later
Old Dec 5, 2009 | 03:17 PM
trueburton's Avatar
I ordered a cable from ALDLcables.com and should have it by tuesday and i downloaded the software. Is there anywhere on TGO that explains how to interperet all the data and what should be doing what and what shouldn't be doing what. Or is the data log info the same as if you were gonna PROM burn? Thanks.
Old Dec 5, 2009 | 05:40 PM
jaykar's Avatar
This is where have to go back to school, sorta of.
Come to think about it, not sorta
Best advice I can think of is go to the DIY Prom board and start going
thru all the threads pertaining to the questions you need addressed.
Get everything set up first so you can log.
Use the search feature.
At the top of the board read all the stickies posted there.
HTH
Later
Old Dec 5, 2009 | 08:32 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Go here https://www.thirdgen.org/forums/diy-...uide-book.html
Old Dec 6, 2009 | 04:32 PM
trueburton's Avatar
yeah i've been there already.
Old Dec 6, 2009 | 08:41 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Well you should have most of the info you would
need. that's how i got started
Old Dec 9, 2009 | 07:31 PM
trueburton's Avatar
well i went to the library ad got a book on Tuning Engine Management systems. Read some of it already and it has been a big help. I think i'll do some more research and get educated. Thanks for the help so far.
Old Jan 23, 2010 | 10:48 PM
trueburton's Avatar
Well i have been reading alot about this tuning but now i can't get my laptop to work with the ECM. the program says the cable is connected but when i click the record button on tuner pro is says there is a problem with data logging. also no information comes up on the screen once i start the car. Not sure if i'm doing something wrong or what. Any advice would be appreciated thanks.
Old Jan 24, 2010 | 03:41 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
You must first create (name) a log file. And then you can choose it.
Old Jan 24, 2010 | 03:56 PM
trueburton's Avatar
you mean like selecting an xdf file? because i did that.
Old Jan 24, 2010 | 04:01 PM
trueburton's Avatar
Ok i created the log file. But it seems as if the computer is not linking up to the ECM. but tuner pro says the hardware was detected. Could there be a problem from the ALDL connector to the ECM?
Old Jan 25, 2010 | 03:50 PM
trueburton's Avatar
any ideas?
Old Jan 25, 2010 | 08:12 PM
witnlyn's Avatar
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
are you using tunerpro RT V5, you also have to select an adx. file
Old Jan 25, 2010 | 09:06 PM
trueburton's Avatar
yes i got it to work now but the numbers coming up make no sense. Also, is the PROM ID supposed to continually change? that doesn't seem right.
Orr89RocZ
Apr 25, 2016 08:28 AM
89fast5oh
Sep 27, 2015 09:04 PM
bamaboy0323
Sep 3, 2015 06:07 AM
CORV3TT3
Aug 23, 2015 11:26 AM
overdriv
Aug 20, 2015 03:52 PM
