ALDL not working
Old Dec 9, 2009 | 08:26 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
ALDL not working
my ALDL will not communicate with my ECM. The ECM is new. was wondering if there is a fuse or something simple that others have found to cause this problem before i start searching for bad wires in the dash. Thanks.
Old Dec 10, 2009 | 07:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ALDL not working
There isn't a fuse in the ALDL line if that is what you are thinking. At key-on/engine-off the SES should turn on, blink off, then turn on solid. As long at it does that the ECM has power and is running from the PROM.
Note that a 10K resistor is required between A&B on the ALDL connector to scan your ECM. Although the resistor can and should be removed once communication has been established.
RBob.
Old Dec 10, 2009 | 03:11 PM
trueburton's Avatar
I read about that 10K resistor and it said some cars need it and some don't but didn't clarify which did or didn't. I will try that Thanks for the help.
Old Dec 11, 2009 | 04:58 PM
trueburton's Avatar
Well i tried the 10K resistor and it didn't fix anything. I also checked my ALDL ports that connect to the ECM and they were bouncing from 3.5-4.3 volts and kept bouncing back and forth. That doesn't seem right but i'm not sure what would cause that. Also i checked the voltage at the ECM A6 and A9 pins. One was at 5.0 constant, other a constant 11.50. I don't get it whats goin on?
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
