code 13,14 low temp high temp
Car: 78 Camaro, 84 Z/28
Engine: Vortech blown 383,stock 305
Transmission: built TH350,5 speed
Axle/Gears: Richmond 3:42 froged posi, 3:23 sto
Hi, I am new to the third gen. Have a second gen for over 30yrs. Always wanted thrid gen, just bought 84 z/28. I don't know much about ECM. The temp. gauge does not work. Can see what I believe to be sending unit in water jacket, wires hooked up. Is there another sending unit somewhere elese?
Re: code 13,14 low temp high temp
Will this cause problems with way the car runs? Does not seem to run hot, is a little rich. The light comes on only after running a few minutes.
Car: check
Engine: check
Transmission: check
The ECM uses a sensor that is in the top front of the intake manifold (2 wire).
RBob.
Thanks I will check those and see if that will fix it
