How far with a stock prom?
Car: 86 IROC-Z
Engine: LB9 5.0 tpi
How far can you go with a stock prom on a TPI based car? A long time ago, with my old TPI I had to go carb, due to lack of tuning ability on a prom burners part. I had two chips burned from [a sponsor] and both ran worse than teh stock chip did, but the stock tune would not idle at all. It would periodically idle up and down and then die going down the road. The cam was a very baby cam 224/230 on a 100 shelf grind from comp. I never could get it to idle and after 2 chips I gave up after a certain tuner told me the cam was too big.....??? So, IF I were to pick up another TPI car should I go ahead and go DFI or is there competent tuning available?
Car: 1983 G20 Chevy
Transmission: 4L60
Re: How far with a stock prom?
My G20 vans current 350 has almost identical specs at .050"....Ported Vortecs....TPI....Running on a later model TBI PCM from a 1995 Truck....My own custom calibration in it.
Car: 86 IROC-Z
Engine: LB9 5.0 tpi
Yeah I know, As far as Cam's go, I had to ORDER that cam because we never kept things that small in stock. I don't know what the deal was but it rarely ever idled.
I see you are from Hurst, I used to live in NRH and graduated from Birdville. Cool to see people from places I know.
Car: 1983 G20 Chevy
Transmission: 4L60
Yea Birdville is real close I had a few friends that went there, I went to Bell. I actually live across town by Trinity now.
Car: 86 IROC-Z
Engine: LB9 5.0 tpi
The aftermarket tune I got burned more fuel than a refinery, and foulded plugs like it was going out of style. I tried one more time with this tuner and that one wouldn't run at all. After that, I called another tuner who immediately said that cam was too big for TPI cars. SO I went carb. Shame.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 86 IROC-Z
Engine: LB9 5.0 tpi
Ah I see, I did not gave access to the tuning software myself as we did not hardly ever see TPI cars in the shop, since we were primarily an LSX shop.
Car: 1983 G20 Chevy
Transmission: 4L60
Another thing I have played with is an 0411 LS1 PCM running a TPI engine using an 02 Express Van L31 Vortec tune and electronics.
I am going back OBDI because the OBDII stuff is not as defined as the older stuff and its not as easy to completely dial in when you have tables that are not defined 100%.
Car: 86 IROC-Z
Engine: LB9 5.0 tpi
Yeah don't get me wrong we did a ton of SBC/BBC/SBF/BBF and Modular stuff, and of course LT1 stuff because I was the resident LTX guy, but LSX was/is the primary market. And our record setting shop car was an LSX car. I gave the TPI a shot, but as little experience I had with it I could only go off of what I was told by other tuners which was to give up basically. Now I am currently selling the empty iroc-z shell and grabbing something else.
Genopsyde
Oct 7, 2015 08:35 PM
Sanjay
Aug 12, 2015 03:41 PM
