Any way to get vss signal to my speedo without ecu?
Old Feb 22, 2010 | 02:04 PM
73duster's Avatar
I have an aftermarket cobalt electronic speedo for my 91 z28. I'm going to remove the ecu because i'm converting to a fast ez fuel setup to control the tpi. I just want to know if there is a way to get the proper vss signal to the speedo once the stock ecu is gone. It is currently running of the buffered signal from the ecu. Is there an aftermarket converter?
Old Feb 22, 2010 | 08:51 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Any way to get vss signal to my speedo without ecu?
It depends upon what your spiffy cobalt electric speedometer requires for a signal. A 5-dollar 4-out buffer will provide a 2K or 4K PPM digital signal from the stock VSS. And feed the cruise control. Or can go after market and get a SGI-5 Dakota digital box for a bunch more. Which may or may not work. Which goes back to depending upon what the cobalt speedometer requires for an input signal.
RBob.
Old Feb 22, 2010 | 09:30 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I know from asking a few folks, that my MAF-ECU can take it's leave and the speedo can work independently. Not sure if that holds true for a SD car.
If you get your EZ-EFI hooked up before I do, lemme know how it goes.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
KO1
16
Oct 15, 2015 05:00 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lewandom
Oct 1, 2015 08:15 AM
