Need a pic/pinout of Aldl connector to ecm for 730
Old Mar 8, 2010 | 01:39 PM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
I think my aldl connector is mis-pinned. IIRC i pins in slots: A,B,C,F and maybe J/K (don't know). I would love to have a pic of someone's connector to see what wrong with mine. I just rebuild the engine and wanted to do some datalogging. Well I have a usb aldl connector and when I put the jumper on the pins at the usb side, the ecm goes into service mode but will not allow the computer to connect to the ecm. Also does someone have a wiring diagram from the connector to ecm incase the PO did some hack job(that maybe explains the mispinned connector). that way i can shoot the wires from each one to find the correct wire for the correct port. thanks
Old Mar 9, 2010 | 11:52 AM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
Re: Need a pic/pinout of Aldl connector to ecm for 730
I took another look and I have the following pins in the ALDL connector: A,B,C,F,K,M. Can ANYONE help me out, I took a look at this website and got printouts of this diagram but I would REALLY like it to data log but every program I use will not connect. On my aldl cable, should I be making the ecm go into service mode to data log or just plug in with jumping the A/B terminals?
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Old Mar 9, 2010 | 05:09 PM
witnlyn's Avatar
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
not sure what your cable is like but I don't think you need the jumper on a 730 ecm
F.I. 57 Belair
Aug 23, 2021 01:09 AM
gta892000
Aug 11, 2019 11:16 AM
greenyone
Sep 8, 2015 08:41 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
