Cop Car Injectors and Ecm
Old Mar 15, 2010 | 04:35 AM
got_tork's Avatar
Car: 92 RMW
Engine: L05/350
Axle/Gears: 3.23Posi
Went to the local Pull A Part yesterday and pick up 9C1 injectors and ecm.I have a few questions.I want to put the parts in my 92 Roadmaster Wagon.
1 Do I need the ESC or any other sensors from the Caprice?
2 The service No.on the ecm is 16136965 and the code on the prom is AYDP 4623 are these correct?
3 Do I need to chage the base timing? fuel pressure is set at 12psi
Old Mar 15, 2010 | 11:58 AM
Ronny's Avatar
Re: Cop Car Injectors and Ecm
Check this out: https://www.thirdgen.org/forums/tbi/...3-350-9c1.html
What CID is your engine?
Fuel pressure should be fine as that was the GM setting. Better Q is your fuel pump adequate?
Old Mar 15, 2010 | 04:09 PM
got_tork's Avatar
Car: 92 RMW
Engine: L05/350
It's a stock 92 350 cid only mods are cold air intake and took the air horns off the top of the tb and made ajustable regulator.I have a 670 Holley unit I picked at P.A.P. for 20 bucks and a LT1 cam that I wanna put in when I get some time. As far as the pump it seems to be all right.The link you posted seems to have a lotta info the only problem is that I'm not at that level yet all seems pretty complicated.
Old Mar 15, 2010 | 04:32 PM
Ronny's Avatar
The cam require a tune.
Old Mar 15, 2010 | 04:55 PM
got_tork's Avatar
Car: 92 RMW
Engine: L05/350
Yeah that's what I've read my one buddy has done some data logging and the sent the data out and had chip burned.It would be nice to find someone local to tune the car
Old Mar 23, 2010 | 11:05 PM
rocko350's Avatar
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
Good to see you over here tork!
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
djmarch
Aug 10, 2015 08:42 AM
djmarch
Aug 9, 2015 05:27 PM
