Identifying injectors
Old Apr 23, 2010 | 01:23 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
The guy I bought my T/A from gave me alot of spare parts including a set of injectors that he was gonna swap in. I have no idea how much these flow or anything else about them. The plastic on these are pink where the stockers are black. Other than that they look identical. Does the pink signify anything? The original owner was gonna swap a 350 in so I assume these injectors were intended for that motor not the 305.
Old Apr 23, 2010 | 10:14 AM
Ronny's Avatar
Re: Identifying injectors
"search" the number on top of injector. there was a thread on part #'s a couple months ago.
Old Apr 23, 2010 | 10:36 PM
RSFreak's Avatar
Where is the number located?
Old Apr 24, 2010 | 07:59 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I just did an internet search for Ford Pink Top Injectors and came up with 21# on one site and 22# on another. So, yes, they would be intended for a stock 350 setup.
Old Apr 25, 2010 | 02:06 AM
RSFreak's Avatar
How many lbs. are the 305 injectors?
Old Apr 26, 2010 | 09:31 AM
Ronny's Avatar
My error. I thought you had TBI. I am uncertain of part numbers on TPI injs.
Old Apr 26, 2010 | 04:47 PM
witnlyn's Avatar
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
stock 305 is 19#
Old Apr 26, 2010 | 06:12 PM
southbay08's Avatar
send me the part number and i will tell you exactly what size they are.
Old Jun 23, 2010 | 03:42 PM
C305's Avatar
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
i also have ford injecotrs that were on my 305 top is pink black is bottom one side says 0 280 150 561 the other side says fote 9f593 d9b and theres 957 written were the plug is and 285 on the flat part can you tell me what they are.
Old Jun 23, 2010 | 03:45 PM
C305's Avatar
Car: 91 camaro vert
Yea thats what i was thinking because the heads never changes so aslong as its matchd to that it should seal no matter what the bore on the block is,thanks for the help
Old Jun 23, 2010 | 04:14 PM
southbay08's Avatar
they are rated 22lb @ 3 bar
www.southbayfuelinjectors.com
Old Jun 24, 2010 | 01:03 PM
C305's Avatar
Car: 91 camaro vert
Thank you I just bought a set of 24lb for the 350 im putting in would these 22lbs work good for a modified 350 or am I better off with the 24lb and sorry about that other post it was suppose to be in a different thread.
92-Formula
Dec 12, 2015 10:34 PM
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
