FI TO CARB HELP!!
Old Jun 27, 2010 | 11:34 PM
tgraham77's Avatar
Car: 92 RS-2007 Tundra
Engine: 375hp/350-384hp/5.7l
Transmission: 4 spd auto-6 speed auto
FI TO CARB HELP!!
Hey guys my son and I are doing a 305 to carbed 350hp 350, I am understanding that i can use my current harness and cut back unused wires. This way my stock tach and dash is unaffected, am I right because I am not sure about all the fuctions of the ecm. Some clarification would be great thanks!!!
Old Jun 27, 2010 | 11:36 PM
tgraham77's Avatar
Re: FI TO CARB HELP!!
The car is a 92!
Old Jun 28, 2010 | 01:23 AM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
was the car originally TBI or TPI? You will need a wiring diagram to figure out which circuits to keep. The tach, coolant temp, and oil pressure are easy. The speedo depends of which you had. TBI cars had a buffer box between the speedo sensor and the gauge cluster. TPI cars had this function inside the ecm. I need to know what harness is on the chassis to give you the right diagram.
Old Jun 28, 2010 | 08:07 AM
tgraham77's Avatar
It is a TBI, what functions does the ecm have and will i still be using it? Thanks for your help we will put some pics up soon.
Old Jun 28, 2010 | 06:54 PM
Car: 1992 Camaro RS
Transmission: WC T5
You won't need the ecm to drive anything unless you have a 700r4 or 4l60 4 speed auto trans with a lock up torque converter. You'll need a lockup control kit to make this work. Don't discard that ecm. You never know when you or someone else is gonna need that box.
You will probably have to rewire the starting circuit to remove the VATS (vehicle anti theft system) so it will start with out the ecm. When I get home tonight I'll post up the wiring diagrams for the TBI car.
Old Jun 28, 2010 | 07:41 PM
tgraham77's Avatar
I am keeping the what i believe is the 700 r4 auto 4 speed
Old Jun 28, 2010 | 10:15 PM
Car: 1992 Camaro RS
Transmission: WC T5
If its oe then its a 4L60. Its the same as a 700-R4. You'll be able to drive without the lockup torque converter function it'll just make less gas mileage. I dunno how much I never ran mine without it to see the difference.
Old Jun 29, 2010 | 12:58 AM
Car: 1992 Camaro RS
Transmission: WC T5
Here's those diagrams i promised.
Attached Thumbnails FI TO CARB HELP!!-diagram_1992_vss_v8_vine.jpg   FI TO CARB HELP!!-diagram_1992_throttle_body_injection_v8_vine_ignition_and_ses_and_tachometer.jpg   FI TO CARB HELP!!-diagram_1992_throttle_body_injection_v8_vine_tcc.jpg
Old Jun 29, 2010 | 01:00 AM
Car: 1992 Camaro RS
Transmission: WC T5
TBI diagrams continued.
Attached Thumbnails FI TO CARB HELP!!-diagram_1992_throttle_body_injection_v8_vine_emission_controls.jpg   FI TO CARB HELP!!-diagram_1992_throttle_body_injection_v8_vine_engine_data_sensors.jpg   FI TO CARB HELP!!-diagram_1992_throttle_body_injection_v8_vine_fuel_injectors.jpg
Old Jun 29, 2010 | 01:01 AM
Car: 1992 Camaro RS
Transmission: WC T5
TBI wiring diagrams continued.
Attached Thumbnails FI TO CARB HELP!!-diagram_1992_throttle_body_injection_v8_vine_idle_speed_control_and_fuel_control_and_vehicle_dat.jpg   FI TO CARB HELP!!-diagram_1992_throttle_body_injection_v8_vine_spark_control.jpg   FI TO CARB HELP!!-diagram_1992_starter_and_charging_system_v8_vine_charging.jpg
Old Jun 29, 2010 | 01:05 AM
Car: 1992 Camaro RS
Transmission: WC T5
TBI wiring diagrams continued....
Old Jun 29, 2010 | 01:08 AM
Car: 1992 Camaro RS
Transmission: WC T5
Attached Thumbnails FI TO CARB HELP!!-diagram_1992_coolant_fan_v8_vine.jpg   FI TO CARB HELP!!-diagram_1992_power_distribution_v8_vine.jpg   FI TO CARB HELP!!-diagram_1992_instrument_cluster_pinout.jpg
Old Jun 29, 2010 | 01:10 AM
Car: 1992 Camaro RS
Transmission: WC T5
continued
Attached Thumbnails FI TO CARB HELP!!-diagram_1992_gauges_part1.gif   FI TO CARB HELP!!-diagram_1992_gauges_part2.gif   FI TO CARB HELP!!-diagram_1992_gauges_part3.gif
Old Jun 29, 2010 | 01:12 AM
Car: 1992 Camaro RS
Transmission: WC T5
continued....
Attached Thumbnails FI TO CARB HELP!!-diagram_1992_gauges_part4.gif   FI TO CARB HELP!!-diagram_1992_gauges_part5.gif
Old Jul 4, 2010 | 08:58 PM
tgraham77's Avatar
What is the difference between the 2 trannys?
Old Jul 6, 2010 | 01:20 AM
Car: 1992 Camaro RS
Transmission: WC T5
one is manual and one is the four speed auto.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
