87 T/A need info on stock ecm timing control & fuel control carburator, manual tran.
Old Jul 27, 2010 | 03:30 PM
TA Daddy's Avatar
Car: 87 Trans Am
Engine: 305 for now working on 400 sbc
Transmission: 5 speed
Axle/Gears: stock for now
I am planning on installing a 406 sbc, spec. stock bottom end, with 30 cc dished piston (cast) 5.565 rods, Vortec heads milled .010. expecting compression to be 9.3-1.
Cam specs 230 duration @.50 lift, .455 lift it & ex, 114 angle lobe seperation. elderbrock performer intake & hoping to use rework computer controled quadrajet to flow 750 cfm.
this formula is similar to the impersonator 406 super chevy did some years ago. drive line planned is a T-10 from mid 70's TA and a posi 9 bolt w/ 3.27-1 ratio.
I need to know what the computer controled timing controls are set at? What is the max timing in degress and what rpm is it at. I need 35 degrees and around 3,200 rpm or so. Also what air fuel ratio is the ecm programed to keep.
I was hoping because peak toque is 3,600 rpm and peak horse at 5,100 rpm the stock setting would be useable. Plus the knock sensor would hopefully keep the cast pistons last longer. Building it for cruising & 1/4 mile actions once in a while. Any feedback would be greatly appreciated
Car has 305 with 5 speed now eng vin code is H now. Engine swap should be in the next 12months.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
marcusaw
Aug 10, 2015 08:13 AM
djmarch
Aug 9, 2015 05:27 PM
