best runnung collant temp ???
Car: 1991 Firebird, 1997 3000 GT
Engine: V6
Transmission: Auto... 5 speed manual
Axle/Gears: stock
Since I'm replacing the injectors( 91 Bird V6 ), what is the stock thermostat temp and what do you guys run in yours. In my 1970 454, I used a 160 in summer and a 180 in the winter. TIA
Car: check
Engine: check
Transmission: check
Re: best runnung collant temp ???
Best bet is to stay with the stock 195. Otherwise it just won't run right. There is a bunch of stuff in the ECM that is coolant temperature controlled.
RBob.
RBob.
Engine: V6
Axle/Gears: stock
I grew up on non smog machines. Old dogs HAVE to learn new tricks.
Thanks again.
Car: 88 T/A. TOTALLED!! (not by me)
Engine: TPI 5.0
Transmission: 700r4 Auto
Axle/Gears: 2.73 posi
Hi there! New guy here. RBob what is your opinion of using something like this http://www.jegs.com/i/JET-Performanc...oductId=752201 especially in hotter climates (Like S/E Texas, where I live)?
Wouldn't keeping the avg. temp. closer to 195F, rather than over 220F all the time allow the ecm to add a little more timing and make more power without negatively affecting anything else? Maybe even using a 180 t-stat along with that?
Thanks,
J. Campbell
Thanks,
J. Campbell
Engine: V6
Axle/Gears: stock
Engine: V6
Axle/Gears: stock
Engine: V6
Axle/Gears: stock
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
You might want to verify your temp gauge readings..sounds a little fishy.
Engine: V6
Axle/Gears: stock
Picked up 3 MPG ( from 17 to 20 ) combo driving ( city and hyway)
