Backfires at startup with est plugged up, doesn't with it unplugged?
Old Sep 5, 2010 | 09:09 AM
ace_012's Avatar
I have a 7747 with a ASDK bin from moates, got the 305 out of my buddies 90' tbi camaro to put in my truck so I've been trying to burn a prom for it since to get it right. Anyways, as of right now when I crank it with the EST plugged up the rpm's will fluctuate pretty significantly & it will backfire like 5-10 times for maybe 20 seconds then it's like someone flipped a switch and it runs fine all the sudden, no matter what the temp is. I tried it from a cold start this morning and even last night after it was warmed up for a while and it still ran terrible at start up. But I noticed when I was setting the timing to 0* with the EST unplugged it didn't have any problems other then a high idle. So I cranked it again this morning with the EST unplugged, idled high but other then that it was fine.
Anyone know what could cause this? I can datalog both instances if I need to. My buddy is the one with the programmer so I was going to apply the forced knock test patch today and see if that does anything.
Oh and also when the EST was unplugged, winaldl read only 3 knocks, but when it was backfiring it just kept going up to around 20 then I turned it off. And no mods other then the usual headers, no cat, ported heads.
Old Sep 6, 2010 | 04:33 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Backfires at startup with est plugged up, doesn't with it unplugged?
Double check your #5 and 7 wires on the dizzy are not reversed.
That and the #1 position is correct when inserted (not off by a tooth)
Could have all wires shifted on the cap by one position also, usually happens when your in a hurry and just don't notice it ended up that way.
Old Sep 6, 2010 | 09:12 PM
ace_012's Avatar
I'll check to make sure the wires are plugged up right tomorrow morning, but just to clarify the rotor should be pointing at the #1 wire on the cap when it is at TDC and on the compression stroke right? For 0* initial.
eightsixseven
Dec 16, 2024 01:50 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
bamaboy0323
Sep 3, 2015 06:07 AM
dyeager535
Aug 28, 2015 08:10 AM
db057
Aug 22, 2015 08:17 PM
