1991 Firebird "Error" Code Help
Old Sep 11, 2010 | 06:06 PM
K.C.Kustoms's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 l v6
Hello everyone.
I have been trouble with my 1991 Firebird v6 and cant seem to fine the problem. For background story click -https://www.thirdgen.org/forums/elec...d-v6-vats.html
Today I drove it to my local auto parts store thinking I had fixed the engine trouble. But when I came out the thing would not start. It would start stay on for about a minute and then while driving it would just shut right off.
So I left it there and decided to check the codes on a code reader.
The code reader then displayed the following "Code Errors."
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
43. Low voltage at electronic spark timing circuit
54. Low voltage at fuel pump OR Low voltage at Fuel pump relay OR Output failure at quad driver module.
Now I'm not exactly sure what these codes mean or how to fix them so if anyone could help it would be greatly appreciated.
I do have a feeling though that it has something to do with the fuel pump because it sounds like the engine is starving for of fuel.
I put my ear to the gas tank while we tried to start it and I could not hear the pump running.
So, my first thought is the fuel pump. But still am unsure.
Old Sep 26, 2010 | 11:09 PM
triggerman454's Avatar
Car: 1991 Firebird, 1997 3000 GT
Engine: V6
Transmission: Auto... 5 speed manual
Axle/Gears: stock
Re: 1991 Firebird "Error" Code Help
Get a manual and a VOM ( voltmeter) and start checking the voltage at the battery and alternator ,then the terminals from the ECU to the relays, etc.
I had to break ALL my electrical connections and clean them .Then use an anti oxidation paste upon assy. After almost 20 years, corrosion is your worst enemy.
Good luck
Old Sep 27, 2010 | 02:24 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
43 Can Be either high or Low Voltage.. Check your grounds.....
jhawkeye
May 25, 2022 06:33 PM
bjpotter
Jan 22, 2019 12:27 PM
evan555222
Sep 20, 2016 02:51 AM
wild1
Aug 27, 2015 09:01 AM
evan555222
Aug 22, 2015 07:14 PM
