88 IROC lack of spark
Old Sep 29, 2010 | 03:56 PM
Srw1285's Avatar
Car: 1988 IROCZ
Engine: 5.7 350
Axle/Gears: 2.77
I have an 88 IROC with the 350 TPI. It sat for several months and had a dead battery. I put a new battery in it and it fired right up and I drove it all day. Parked it for a week and went to start it and it would not fire. Checked to see if it was getting fuel and it is. Checked to see if it was getting spark and it is not. Replaced the distributor, coil, and control module and still no spark. We also plugged the stock ignition back in to see if it was the Mallory ignition and still did not fire. Put stock chip back in computer and still no spark. Is the computer fried or are there any other things that may be causing it?
Thanks in advance
Old Sep 29, 2010 | 04:03 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: 88 IROC lack of spark
Spark when cranking is provided solely by the distributor. The ECM has nothing to do with spark when cranking. Be sure you have at least 9 volts at the large pink wire at the coil while cranking. Be sure that the two wire harness from the dist to the coil is in good shape and solidly connected. A no spark while cranking, on a stock system is somewhere between the dist and the coil, or the power supply to them, period.
Old Sep 29, 2010 | 04:14 PM
Srw1285's Avatar
Car: 1988 IROCZ
Engine: 5.7 350
Axle/Gears: 2.77
Thanks ASE doc. I will look further into distributor and the coil.
Old Sep 29, 2010 | 04:17 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Definitely test voltage at the coil when cranking. Especially since your battery was dead. You may need to clean up wiring connections to solve your problem. Good luck bro
Old Nov 1, 2010 | 09:51 PM
Srw1285's Avatar
Car: 1988 IROCZ
Engine: 5.7 350
Axle/Gears: 2.77
It ended up being both the pick up and the control module! ha crazy. Thanks for the help!
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
g.l.mos
Aug 22, 2015 12:02 AM
mdtoren
Aug 16, 2015 05:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
