EBL, T56 & VSS
Old Nov 26, 2010 | 08:22 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
EBL, T56 & VSS
I'm getting ready to install a RamJet 350, controlled by the EBL with a T56 into a '92 camaro. I know the VSS on the T56 i pulses different than the one from the camaro, which the EBL uses. Can the value be changed in the EBL system to match the T56 VSS, or do I need to get the Dakota Digital box ? Speedo is not a concern. Or does the EBL need the VSS at all with the T56? This car will see very little street use. It's going to be a Land Speed car! Later, Dean
Old Nov 26, 2010 | 01:39 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL, T56 & VSS
A VSS can he helpful as with a stick you can adjust the added PE SA versus which gear is in use. There is a table of PE SA values versus which gear and RPM. Can use more PE in lower gears then higher gears.
Other then that I don't see an advantage to the VSS in this type of vehicle. There are other items that depend upon it. Such as DFCO, launch mode, BLM cell to use, fan operation, N2O min MPH, and IAC throttle follower decays. However, these probably won't be used.
Note that version 2.2 of the ECM firmware does support a programmable PPM for the VSS. Check the WUD main display. The latest WUD will show the ECM firmware version whenever the engine is running.
This is V2.2f of the WUD.
RBob.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
