New Chip? or not...
Old Dec 25, 2010 | 02:30 AM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
New Chip? or not...
I just purchased an 85 Z28 which originally had the TPI 305 in it. The previous owner put a built 89 TPI 350 in the Z28. Bored, mild cam, ignition system, etc, as well as a different rear end. My question is, the car runs great but I think shes running rich. Does the stock PROM suffice or should I look at a replacement concidering the new engine isnt exactly stock.... If I should look at a replacement can someone point me in the right direction...
Old Dec 26, 2010 | 03:08 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: New Chip? or not...
Ok i Pulled the ECM and found these numbers. The main ECM number is 7-7165 and the code inside of the blue chip is APYU 3516. Previous owner claims that he added a Hypertech chip. Not seeing it, so apparently he was wrong.
Old Dec 26, 2010 | 04:29 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
You now have 3 post with the same questions? Your car is running rich, have you gotten any codes from the ecm?
Old Dec 26, 2010 | 05:07 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Im sorry about the multiple posts, dont know how to take it down from the incorrect area. Honestly I dont even know how to pull trouble codes from these old computers.
Old Dec 27, 2010 | 06:25 PM
Chieftain_57's Avatar
Car: 1957 Pontiac Chieftain Catalina
Engine: 1987 350 TPI
Transmission: TH-700 R4
Axle/Gears: 1957 Pontiac 3.4:1
Here's something for you to read:
http://www.troublecodes.net/GM/
Good luck!
Old Dec 28, 2010 | 10:37 AM
Ronny's Avatar
Consider buying or building an ALDL cable. Datalog while driving. TunerProRT or winALDL. Free program. Read stickies on datalogging.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
