1991 ECM - Yellow Plug???
Old Feb 22, 2011 | 05:39 AM
1991_RS's Avatar
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
I'm building a daily driver 1991 RS with a 305 TBI. The previous owner installed a new (used) ECM. There is a large yellow socket that has nothing plugged into it. Is this supposed to have a plug in it or is it supposed to be empty?
Could this be the reason I'm not getting ignition power to my fuel relay (I can jump it and it works) and also the reason my fuel injectors aren't spraying?
Old Feb 22, 2011 | 06:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1991 RCM - Yellow Plug???
Did the '91s get an air bag? I know the '92s did. With an air bag car a yellow connector is usually for that system. GM went with yellow for air bag systems. Tracers on the wiring, the molded connectors and so on.
They even changed one of the '7730 ECM (not yours) connectors from yellow to light green.
It may be that yellow socket is for the DERM (diagnostic energy reserve module). And the module is missing.
Back to the no power, check the in line fuse under the hood. It resides along the fender well on the passenger side. Heavy gauge wire that runs from the front behind the headlight to the passenger side fire wall.
That fuse provides power to the fuel pump relay socket and the ECM.
RBob.
Old Feb 22, 2011 | 07:43 AM
1991_RS's Avatar
Thanks Rob! I suspected the plug might not be running related (It does have an airbag, but the steering wheel is rough and may get replaced).
The inline fuse you refer to, is that supplying the constant 12v feed to the relay? We do have 12v constant and are able to jump the 12v to the pump feed and get it to run, however, there's no switched power. Am I correct in thinking that the oil pressure switch has no effect on the pump relay until after the car actually starts and generates oil pressure?
Old Feb 22, 2011 | 02:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, it is constant battery +12 volts. So I'd say as you do that the in-line fuse is OK.
That leaves the ECM, which provides +12 volts to the relay coil to operate it. The TBI ECMs use a small transistor that tends to pop. Easy to replace with a PN2907 or 2N2907. If you are handy with a soldering iron there are pictures of it on this board.
The oil pressure switch is a fuel pump relay bypass. Once oil pressure is above about 4 psi the oil switch closes and operates the fuel pump even without the relay. This is a back up to the relay.
RBob.
Old Feb 22, 2011 | 04:09 PM
1991_RS's Avatar
RBob.
Can you post the link for those pictures? I'm not terribly handy but I've got some "people" who are.
Old Feb 22, 2011 | 05:34 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
It sounds to me like there is a 1227730 (or similar) ECM in place of where a 1228746 (or similar) ECM should be.
Old Feb 23, 2011 | 06:02 AM
1991_RS's Avatar
How does one know which ECM is the correct one? (This was the one that the PO installed as a replacement)
Old Feb 23, 2011 | 07:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You know six_shooter, I never thought of that. I figured that the yellow socket was hanging from the harness. And the DERM module is in the area under the passenger side of the dash.
1991_RS, is this yellow socket on the ECM? Along side of the two black sockets? If so it is the wrong ECM, that is a '7730 used on port injected f-body's.
The proper ECM for your TBI set up is the 1228746 ECM. This can be found as the Service Number on the paper label of the ECM. Should only have two black sockets to plug into the car harness.
Link to thread w/picture:
https://www.thirdgen.org/forums/dfi-...swap-ecms.html
RBob.
Old Feb 23, 2011 | 08:27 AM
1991_RS's Avatar
I'll be checking out the ECM shortly. I'll post back what I find. I was beginning to suspect the VATS wasn't working, but reading your posts and the link you posted, I'm thinking the PO didn't know what he was doing.
Old Feb 23, 2011 | 08:37 AM
1991_RS's Avatar
UPDATE: The only number that's still readable on the ECM label is 7750
How does that compare to what's supposed to be in there?
Also, I found one that is supposed to be from a 89-92 TBI car but it also mentions PROM ANTT What's that mean?
Old Feb 23, 2011 | 10:52 AM
1991_RS's Avatar
Talked to a service manager who confirmed that I need the 1227730 (not that I doubted anyone - he just happened to call me back) but could not identify the 7750 on my ECM. He also did not know what the ANTT meant.
Also mentioned that I would need to swap out the PROM chip. How do I know if my current PROM chip is the wrong one? Are there other model cars with the same one?
Old Feb 23, 2011 | 12:42 PM
TBI does not use the '7730. The proper ECM for your car, as RBob said, is the 1228746.
The '7730 was used for the TPI cars.
I've also not come across a "7750", is it possible that the sticker is damaged, and it's actually a '7730?
Old Feb 23, 2011 | 01:16 PM
1991_RS's Avatar
Dang, you're good! Upon looking at it with a magnifying glass (no joking!) what's left of the printing looks like a 7730.
That being the case, I might have a line on the 8746, however, is it just a "plug-n-play" situation, or will I need to swap PROM chips inside it too? If so, how can I check to see if my chip is the correct one for my car?
Old Feb 23, 2011 | 01:27 PM
The MEMCAL in the '7730 will not be correct for the '8746.
The '8746 uses an EMPROM that is a 24 pin and is in a small holder. The '7730 uses a MEMCAL that is larger with more inside it.
The 4 digit broadcast code will indicate what the EPROM is for. There is an excel file on the moates.net site that lists most of the BCCs available and what their application was. It's a great resource.
I may have one at home that I can check what EPROM it has, if you get one that is not correct.
Old Feb 23, 2011 | 01:43 PM
1991_RS's Avatar
Thanks SixShooter. I'll let you know what I end up with. The guy that may have one is about an hour and a half drive from me and I won't be able to get down there until the first weekend in May.
Old Feb 25, 2011 | 06:04 AM
1991_RS's Avatar
Apparently, I have a 7730 ECM with a 7419 chip (J-car). Thanks to 34blazer for letting me know what the chip was.
The whole ECM is for sale, $35. Pictures are here:
https://www.thirdgen.org/forums/album.php?albumid=4446
send me a PM if interested.
*** Due to no interest on thirdgen.org, the ECM has been listed on an auction site ***
Old Feb 25, 2011 | 06:15 AM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
AWNX is the BBC on the memcal
Old Feb 25, 2011 | 07:41 AM
1991_RS's Avatar
See - that's how you know we're a newbie with the F-car.
What BBC should I be looking for when I pick up the replacement one? Our car is a 5.0 TBI with the 700r4 trans.
And for the sake of parts store people, it has AC and black carpet
Old Feb 25, 2011 | 08:29 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
ANTT will work. The latest calibration is AXKT (auto, FED).
RBob.
Old Mar 7, 2011 | 06:04 PM
1991_RS's Avatar
Old ECM has been sold.
Thank you everyone for the input. We'd still be cussing and scratching our heads if you all hadn't replied!
deracer
Apr 11, 2016 12:04 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Jae992
Aug 27, 2015 09:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
