May have to swap ECM's - help !!
Old Dec 20, 2005 | 03:07 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
My ECM may be bad, going to do some tests today, regarding Code 42 and Code 54. Now IF my ECM would be bad, due to fried fuel pump driver and something else, my question is:
Can I replace it with ANY used ECM from the 3rdGen Camaro's ? Would an ECM from a V6 or carbed V8 work ? Does the ECM have to be from the same year ?
Mine's a 91, and I don't see too many 91-92 RS with the L03 engine at the junkyards, mainly V6's and a few carbed V8's
Old Dec 20, 2005 | 04:24 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You need a TBI car ECM. Either a camaro or B-body varient. If you happen to find say a caprice with a 350, grab the ECM, then put your current prom chip in it. Save the 350 chip though, makes a good starting point, should you upgrade to a 350 TBI down the road.
Old Dec 20, 2005 | 05:22 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
OK, thanks. It has to do with the VATs thingy as well huh ?
One mroe question ... any way to check if the fuel pump driver may be fried on the ECM ?
Old Dec 21, 2005 | 06:26 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The direct replacement ECM is the 1228746. This can be seen as the service number on the label. As for needing this one it has mostly to do with the type of EFI system.
The fuel pump (FP) driver is a common problem, and easy to fix. It is a transistor on the main board. I use a 2N2907 to replace it.
To test it: at key on the FP driver supplies +12 v (battery voltage) to the fuel pump relay for 2 seconds. A DVM can be used to measure that voltage. Make sure to either leave the relay in place or provide a 100 ohm load. Otherwise the voltage measured will not be correct.
The relay coil should measure around 60 ohms. Anything less then 40 ohms and the relay is bad.
RBob.
Old Dec 21, 2005 | 12:11 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Oh ok. Well I got this far
https://www.thirdgen.org/techbb2/sho...hreadid=336997
with my tests, so it's not the relay, according to the tests, even though I wish it would just be the relay heh ... a 10 bucks fix.
Can I drive the car, gently, if I have a Code 42 ?
Old Dec 21, 2005 | 03:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yea, if you grounded the FP relay drive, the transistor is toast.
As for code 42, is the SES on solid? If not then the code 42 was an intermittent. Code 42 will also set if the engine is started with the bypass open (such as when timing it).
Can clear the codes with the battery dance and see if it comes back.
RBob.
Old Dec 21, 2005 | 03:36 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
The Code 42 seems to be constant. I had huge problems starting the car, had to apply throttle or it would die out.
Reason I'm asking is, need a ride to the junkyards
Old Dec 21, 2005 | 04:03 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Good news !
The EST connector must have been not fully seated, or something anyway, no code 42. Of course fuel pump circuit problem is still there, but I bypass that one, and no Code 42.
So in order to fix the fuel pump drive, buy the transistor, which they should have at radioshack, take out the ECM, open it up, and solder the replacement transistor in ?
It MAY be the "easier" option, compared to getting another ECM at the junkyards, because, no offense to Hispanic people, but all the Mexicans at the junkyards take out all the good stuff from the cars.
I STILL haven't been able to find an adapter for the wheel locks on the 91 RS wheels, i.e. the Z28 style wheels.
Old Dec 21, 2005 | 04:12 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Well great, Radioshack don't carry the 2N2907 transistors, so where would I get one ?
Old Jan 13, 2006 | 08:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This picture shows a 2N2907 in place of the original transistor. The harness connector is to the left. While the transistor is opposite of the heat sink.
RBob.
Old Jan 13, 2006 | 09:38 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Just to the right of the resistor ?
Right on.
(gotta relearn the color coding for the resistors again)
Old Jan 22, 2006 | 06:05 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Geeze, yanking the ECM out was harder than I had imagined, the assembly had some damn wiring wrapped around it, on top, had to remove front speaker (luckily I had the dash off already) to see what was going on.
OK, now I just have to take the circuitboard out of the box so I can flip it over, remove the transistor and solder in the replacement one.
Right on. Babe's running now without hotwiring the pump.
Old Apr 26, 2010 | 12:37 PM
tmatt's Avatar
Re: May have to swap ECM's - help !!
Where can I find the transistor that I need? I can't seem to find it at radio shack
AussiePr0nCar
Mar 6, 2020 04:04 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
