ostrich help
Car: 1987 tpi camaro not sure of motor
Engine: 5.0 tpi
Transmission: 5spd
Axle/Gears: posi track rear end gears unknown
ostrich help
ok i am borrowing a ostrich tuner from a friend and it is has the usb connector on it. I am also using tuner pro rt. Well i conenct it to my computer and the connect it to the cars odb1 connetor. All of this is done with the car turned off. Well when i turn the car ignition to the on position, my ses light flashes and i hear the fans kick on and when i click emulate on the software nothing happens it keeps saying no hardware found. i installed drivers from when it was connected to the internet but i was not sure if i have the right drivers. Anyways What am i doing wrong. All i am really wanting to do is see what my sensors are doing and see if anything is going wrong. any help will be appreciated much
Car: check
Engine: check
Transmission: check
Re: ostrich help
If you are data logging, then an ALDL cable is used between the ODB-1 port (ALDL port) and another port on the laptop.
RBob.
Engine: 5.0 tpi
Transmission: 5spd
Re: ostrich help
yes i have that aldl cable that goes from the odb1 port to the ostrich. I am just not sure whee the settings for the switches need to be on the ostrich. It has two switches. One switch has 3 settings and the other switch has only 2 setting. The one with 3 setting is vertical and moves up and down and the other switch is horizontal and moves left to right. If i have the switch that is vertical all the way down it flashes the ses light and i hear the fans come on. In any other positions it is just fine nothing happens
Car: check
Engine: check
Transmission: check
Re: ostrich help
Can find the switch settings on moates.net, they may also be printed in small print on the label.
RBob.
P.S. why is it I suddenly get the feeling that this is an AutoProm, and not an Ostrich...
Engine: 5.0 tpi
Transmission: 5spd
Re: ostrich help
maybe thats what my problem is
Engine: 5.0 tpi
Transmission: 5spd
Re: ostrich help
it has two switches on the back of the unit. one switch is verticle and has 3 setting the other switch is horizontal and has 2 setting what are these switch supposed to be set at or maybe i could jsut call moates and talk to someone
