Need F.I. ECU Expert help
Old May 15, 2011 | 02:53 PM
ghettogmc23's Avatar
To start with i just want to say that i know there are setups out there that are available but im looking to redesign what should have been factory.
The project is a 1991 4.3L V6 TBI
What im trying to do is create a true fuel injection system that is very cost effective.
I want to take the factory 4.3 tbi intake manifold and put fuel rails on it similar to this design:
The fabrication will be easy because i have access to a machine shop. The problem i face is tuning.
I want to keep this cost effective so im wanting to use a factory-style ecu setup, so no megasquirt or anything.
All im needing help figuring out is how do i go from an ecu firing two injectors to firing 6 injectors?
Old May 15, 2011 | 03:48 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Need F.I. ECU Expert help
depends on what ECM you want to run...
and what kind of injectors as well. if you're going to try and run 6 peak/hold, then you're going to limit your options, but 6 saturated injectors will run on nearly any ECM.
Old May 16, 2011 | 08:07 AM
I was hoping to run LS1 style injectors just because they seem the most common to get in different flow rates.
Also the ecm im using is what im not sure of.
I know the GMC Typhoon runs a fuel injection similar to this from the factory and doesnt use a cam sensor or anything. Thats the only ecm i can find that does. I was hoping to get some others that are a little easier to find but im not sure what other GM v6 runs fuel injection other than the OBD1 vortec 4.3
Old May 16, 2011 | 01:53 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Have you checked this out?
http://www.dynamicefi.com/
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
djmarch
Oct 2, 2015 10:41 PM
