need help tuning 400 sbc with super ram
Old Sep 4, 2011 | 10:06 PM
charles power's Avatar
Car: 87 IROC
Engine: 400sbc, pro comp alum he, super ram
Transmission: street strip 700r 2800 stall
Axle/Gears: 3.70 posi
I'm new to the tuning scene and man it shows.
I'm running a 400 small block with stock internals (rebuilt) procomp heads 190 with 64 cc gasket match ported to felpro 1207 intake gaskets, comp cam 280xfi .552in .547ex 113 lobe seperation with 1.6 roller rockers and matched springs and push rods. Fully ported super ram with bbk 52mm throttle body and tpis afpr set at 45psi, and 30lb injectors. Trans is a 700r4 2800 stall b&m torque converter klone steels alto reds kevlar bands transgo valve body and shift kit. Out back is a 3.27 9 bolt posi for now.
Everything is run by accel gen 6. having problems with fuel curves its running rich .
I was wondering if anyone has a setup close to or like this that could help me out or even a place to purchase a program to run this setup
thanks for any help or comments
Charles
Old Sep 5, 2011 | 09:47 AM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: need help tuning 400 sbc with super ram
you might try lowering fuel pressure to 38 lbs.
Old Sep 7, 2011 | 04:16 PM
mistaben's Avatar
Car: 91 corvette
Engine: 383SR
Charles
wait what pcm are you using?
Old Sep 7, 2011 | 08:52 PM
Car: 87 IROC
using accel gen 6 with calmap 6.32 ecm #015013
Old Sep 9, 2011 | 06:18 PM
efiguy's Avatar
That's old but good stuff for it's time. As mentionmed try lowering fuel pressure first to see what happens.
If you need something further let me know, I'm an Accel EMIC.
Old Sep 9, 2011 | 08:28 PM
Car: 87 IROC
dropped the fuel pressure down to 40psi with the vacuume hose off car runs alot better ( thanks old z mzn ) but i can't seen to get it to idle under 1500 and now its lean going to reset the timing tps replace the plugs and see what happens
Charles
Old Sep 13, 2011 | 09:16 PM
Car: 87 IROC
set the timing at 16 deg inital,tps at 0.54, volts dropped fuel press to 38 psi. its running rich black smoke out the back idle is now at around 1000 rpm
any ideas
ready to go carb
Old Sep 13, 2011 | 10:03 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Set base timming to factory spec of 6 degs, tune timing.
I know some disagree but I like higher fuel PSI. You will get a better more complete burn from higher fuel psi due to smaller droplets. I run 47-51 in all my cars. Again you will need to tune it for best results.
Either find a friend or very good shop to teach ya or do it.
Dont give in to carbs!!!
Old Sep 13, 2011 | 10:40 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
is this a maf or sd setup? sfi or batch fire?
when you change your timing you must let the computer know the correct timing.
Old Sep 13, 2011 | 11:00 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
http://www.calibratedsuccess.com/Media.htm
I know it is fun to start pulling levers and magically hope for power to appear, but this will tell you how to do it on purpose.
Old Sep 14, 2011 | 04:17 AM
Car: 87 IROC
its a speed density system 1 bar map with the batch fire
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Stangski09
Nov 14, 2015 01:27 PM
IROCtometal
Sep 2, 2015 02:01 PM
