Removing ECM
Old Sep 8, 2011 | 08:33 PM
scubasteve's Avatar
Car: 84 Z28 T-Top
Engine: L69
Removing ECM
I have no emmision controls,a vacuum advance distributor, a non electric carb. and a 700R4 trans. Can I remove the ECM and if so, how do I wire the TCC to engage manually?
Old Sep 9, 2011 | 09:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Removing ECM
You'll more than likely need a TCC lockup kit, available from TCI, Painless, etc. - about $100. You have to drop the pan on the tranny to wire it up - so might as well add the cost of new tranny fluid, new tranny filter, and a drain plug to get installed into your pan while it's off (so you don't hjave to deal with tranny fluid spillage ever again).
Also good time to install that shift kit you've been wanting (since pan has to get dropped anyway).
There's more info on TCC wiring and operation in the carb forum stickies.
Yes, can remove the ECM - it's not even doing anything now anyway without the cc dist.
Old Sep 9, 2011 | 11:36 PM
scubasteve's Avatar
Car: 84 Z28 T-Top
Engine: L69
Re: Removing ECM
Just what I wanted to here! Thanks for the response, U guys are GREAT
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stryker412
Sep 7, 2015 09:11 AM
willyjoejr
Sep 3, 2015 09:26 AM
RyanJB
Sep 2, 2015 01:27 PM
