PLEASE HELP! High idle!!!
Old Sep 21, 2011 | 07:50 PM
puttputt's Avatar
Well i'm not car expert so i'm gonna try my best. I'm not even sure i'm on the right message board so if im not tell me which one i should be on. I have a 1992 firebird 3.1 liter v6. It is idling at 2000 rpm for some reason. I tested MAP sensor and it is fine (I tested it using a vacuum pump and monitoring voltage) I have the all data info and followed code 33. It results in "Open Ckt 470" which is the blace wire on the map sensor connector. Does anyone know what that means or how I should go about repairing it??? Thanks.
Old Sep 22, 2011 | 01:04 AM
affliction1's Avatar
Car: 89 chevy camaro rs
Re: PLEASE HELP! High idle!!!
i would checkk for vac leaks,spray carb cleaner around the whole intake,if its leaking youll hear a change in idle.and pull the iac off and spray it with carb cleaner really good put it back in and check.this is iac incase you didnt know just spray the spring with carb cleaner
Old Sep 22, 2011 | 02:48 PM
puttputt's Avatar
Sweet thanks for the info! I'll do that and I'll let you know how it goes.
Old Sep 22, 2011 | 02:50 PM
88transam 88's Avatar
Car: 1988 TransAm
Engine: sbc 9:8:1 cr 40os slugs rhs heads
Transmission: th400 3800stall b&mkit manual vb
Axle/Gears: stock
ya it could very well be only a vacum leak but could b more
Old Sep 22, 2011 | 05:47 PM
puttputt's Avatar
Ok I checked for vacuum leaks and did not find one. I sprayed all hoses and there were no changes in RPM. Now i'm reading code 34 which also involves either vacuum leaks or bad MAP sensor. Could it be a faulty map sensor??
Old Sep 23, 2011 | 12:55 PM
did you spray the intake gaskets to?in between upper and lower intake?lower intake?throttle body gasket,iac,break booster hose,map vacum line.just makin sure you dont over look one
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
