trouble codes
Old Dec 30, 2011 | 11:09 AM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
trouble codes
how do i determine how many flashes is what trouble code for example is 12 flashes code 12
Old Dec 30, 2011 | 11:17 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: trouble codes
when you enter into diagnostic mode on obd1 and you are counting the blinks of the check engine light. it will flash 12 three times. to count you will see a blink followed by a second blink. after the three 12's than any other codes will blink there is a slight pause between numbers.
Old Dec 30, 2011 | 11:35 AM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
Re: trouble codes
so code 12 goes flash pause flash flash pause pause and this happens 3 times i only know code 12 what are the others
Old Dec 30, 2011 | 11:42 AM
Engine: Lb9
Transmission: M20
Re: trouble codes
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 26 Quad Driver Module (QDM A) error
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 31 Gear Position Switch (PRNDL) error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 36 4T60-E Shifting Error
DTC - 37 TCC brake switch circuit error
DTC - 38 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 39 TCC error
DTC - 41 Ignition control error
DTC - 41 MEM-CAL error
DTC - 41 C³I Cam Sensor Signal error
DTC - 42 Ignition bypass circuit error
DTC - 43 Knock sensor error
DTC - 44 Oxygen sensor error (lean condition indicated)
DTC - 44 Left bank O2 sensor error (lean condition indicated)
DTC - 45 Oxygen sensor error (rich condition indicated)
DTC - 45 Left bank O2 sensor error (rich condition indicated)
DTC - 46 Pass-Key II (VATS) system error - circuit out of freq range
DTC - 47 UART (serial data) circuit error
DTC - 51 PROM error
DTC - 51 Incorrect MEM-CAL
DTC - 52 Fuel cal-pak incorrect or missing
DTC - 53 System voltage too high
DTC - 53 Digital EGR Valve solenoid 1 error
DTC - 54 Fuel pump circuit low voltage
DTC - 54 Digital EGR Valve solenoid 2 error
DTC - 55 ECM error
DTC - 55 Digital EGR Valve solenoid 3 error
DTC - 56 Quad Driver Module (QDM B) error
DTC - 57 Boost Control error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 58 VATS system error
DTC - 59 Trans fluid temp sensor circuit error (high voltage)
DTC - 61 A/C system performance
DTC - 63 Right bank O2 sensor circuit error
DTC - 63 MAP sensor circuit signal voltage high (low vacuum indicated)
DTC - 64 Right bank O2 sensor lean exhaust indicated
DTC - 64 MAP sensor circuit signal voltage low (high vacuum indicated)
DTC - 65 Right bank O2 sensor rich exhaust indicated
DTC - 66 A/C pressure sensor circuit error (low pressure indicated)
DTC - 67 A/C pressure sensor circuit error
DTC - 68 A/C clutch relay circuit error (shorted to ground)
DTC - 69 A/C clutch relay circuit error (open circuit indicated)
DTC - 69 A/C high pressure switch error
DTC - 70 A/C pressure sensor circuit error (high pressure indicated)
DTC - 71 A/C evaporator temp sensor circuit error (low temp indicated)
DTC - 72 VSS signal circuit error
DTC - 73 A/C evaporator temp sensor circuit error (high temp indicated)
DTC - 75 Digital EGR solenoid #1 circuit error
DTC - 76 Digital EGR solenoid #2 circuit error
DTC - 77 Digital EGR solenoid #3 circuit error
DTC - 79 Transmission fluid overtemp
DTC - 80 Transmission component slipping
DTC - 82 3x Crankshaft position sensor circuit error
DTC - 85 PROM error
DTC - 86 A/D error
DTC - 87 EEPROM error (flash memory error)
DTC - 90 TCC error
DTC - 93 Transmission pressure control solenoid circuit error
DTC - 96 Transmission system voltage low
DTC - 98 Invalid PCM program
DTC - 99 Invalid PCM program
Old Dec 30, 2011 | 11:43 AM
Engine: Lb9
Transmission: M20
Re: trouble codes
some will not apply !!
Old Dec 30, 2011 | 11:46 AM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
Re: trouble codes
so if the light flashes 13 times it is code 13 and thanks for the help
Old Dec 30, 2011 | 11:48 AM
Engine: Lb9
Transmission: M20
Re: trouble codes
it will blink for each number. for example code 12. it blinks once pauses than blinks twice. maybe a video will better assist you.
http://www.youtube.com/watch?v=_3CzHCfz-9A
Old Dec 30, 2011 | 11:53 AM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
Re: trouble codes
so 13 would be flash pause flash flash flash and 28 would be flash flash pause and flash 8 more times
Old Dec 30, 2011 | 11:54 AM
Engine: Lb9
Transmission: M20
Re: trouble codes
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
