After market EFI
Car: 87 GTA
Axle/Gears: 3.42 posi
After market EFI
I have an 87 GTA 350 tpi an i was wondering what is some of the after market efi everyone are using? I was wondering if these adapt to any mods you do to the engine? Also, do these bolt right up and allow me to use factory gauges, nitrous, and msd? I've got a stroker ready to drop in but since no one does proms anymore around here, jus LS stuff i was wanting something that either tunes its self or can be tuned using modern equipment. Thanks for all the help.
U.S. Navy
Godspeed
U.S. Navy
Godspeed
Car: check
Engine: check
Transmission: check
Re: After market EFI
U.S. Navy
Godspeed
U.S. Navy
Godspeed
RBob.
Car: 1987 Trans Am
Engine: LQ9/L92
there is a pretty good thread going in the tpi section on how to adapt the lsx system to sbc setups. readily available parts AND it fits the bill for your local tuning guys
1 Post
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Actually there were two answers in RBob's post, one not so obvious because RBob is a true gentleman, follow the link.
http://www.dynamicefi.com/
But the EZ won't do spark or any power adders. Plus there are other options, Accel offers an easy Nitrous table, just enter the bottle pressure and pill size and it does the fuel map for you. What is the intended use of the car?
if i were in the market to get away from chips and had no plan of adders, what would you choose $9xx for the EZ or $2000 for one of the other systems.
Car: 87 GTA
Its a street car threw the week and race on the weekends. The nitrous is jus a throttle body plate system, 125hp shot.
AGAIN, the EZ is a cost efective system for those that arent going to run adders and want a low hassle EFI system to run their car. if it were to run power adders and control spark it would cost more because of engineering cost. it would cost as much as the other systems with these options.
Why don't you let him decide if he wants 1 box to control just about everything, fans, nitrous, multiple fuel and spark maps, and maybe even some datalogging for the track. Of course it costs more, it does twice as much! Christ!
Dude, he has nitrous. Last time I checked that was regarded as a power adder. Read the post. That's why I mentioned what I did.
But to set the record straight, most, I say most aftermarket systems use pretty much the same capacity boards. They only have so much room in them for management.
Accel doesn't have enough room left to add "self learning", it's that simple, but their fuel overlay program makes tuning a pretty simple task. Ultimately they've choosen to keep and develope calibrations that help drivability, easy nitrous tables and offer a true VE system. I'll explain that in a minute.
BS3 has more datalogging ability than just about anybody in their class, but roughly half the available calibrations that effect drivability etc.
FAST now has "self learning" and has traction control as well as some other stuff, but again fewer transient fueling/aceleration fueling tables etc.
Holley? Avenger and HP have "self learning" and larger fuel and spark tables but again less drivability cals as well as imo less friendly nitrous etc.
And on all speed density systems, unless it takes into account, TPS, MAP, O2, ECT, MST, IAT and can calculate the effect on the incoming air of the ECT, IAT and MST combined they're not a true VE based system, they're pulse width, plain and simple.
I don't know how you can get better engine management than GM code itself which is what EBL is based on. For single purpose cars ie race, perhaps some of the others but for a driver and all around, EBL has a tremendous level of flexibility and capability particularly at its price point. I keep begging
RBob to do the LT-5 version.
One word, junk. Unless you get one for next to nothing they aren't worth it imo.
I have dyno sheets on a 300hp 350 with an HSR and a 950. Then they used the same intake and only changed the electronics to a sequential Accel. Peak hp was about the same with the Accel making 4 or 5 more. But the midrange was a different story, 25-30lb ft of torque difference. And that's right where you drive it.
Car: 87 GTA
I try my best to do as much reading and research as possible but the Navy keeps me pretty busy but if i understand correctly, the EBL is partially a self tuning system? I am trying to learn about tuning and i understand the basics but with all the info on here and with everyone willing to help im pretty sure i can tackle the EBL tuning if thats what the perfered system is? Thanks for all the help.
U.S. Navy
U.S. Navy
Car: check
Engine: check
Transmission: check
The EBL systems have the sensor diagnostics that GM is known for. They also support drive-ability more so then the self tuning, install and forget systems.
And also support the stock smog equipment (closed loop for the cat-con, EGR, CCP, and AIR (EBL P4 only for AIR)). Has support for controlling the A/C compressor and electric fan same as stock.
For an '87 TPI set up the EBL Flash ECM with the Port Mod is the easiest to install. The ECM is the same fit (form factor) as the stock one and only requires a few ECM harness connector terminals/wires moved. Using the MAF wires to wire a MAP sensor to the ECM and it is nearly plug & play.
The MAF may stay in place but won't be used.
Note that the EBL Flash ECM won't run the AIR system. If that is required the EBL P4 Flash ECM will run it. Along with having dual electric fan control. Only downside is that most of the ECM harness connector terminals/wires need to be moved. However, this only needs to be done once.
As for self tuning the EBL Flash systems will self learn the VE tables. Can use either the long term fuel trim in closed loop or a WB set up in open loop for this. The WB also being able to learn at WOT.
Once the VE Learns are complete the WB may be removed.
The EBL Flash ECMs also has a wet N2O control built in. RPM window, minimum MPH, TPS% threshold to engage, and an arming input. An output goes active to trigger the solenoid relays and reduces the SA.
As with the other calibration parameters these to can be set by the user.
The ALDL link and SES light are still active.
RBob.
Car: 87 GTA
EGR, Smog, and A/C have been deleted but it does have the dual fans. From what i read all you need to tune the EBL is a laptop?
RBob,
When is the EBL/Flash LT-5 version available? Puulllleeezzzzeee!!!
Car: 87 GTA
Are the EBL systems as reliable as the other systems out there, i want something that i could possibly tune myself but if i took it to get dynoed the shop could tune it also. thanks
EBL utilizes GM code and a GM ECM as its base. There ain't anything more reliable.
Car: 87 GTA
So would the EBL be my best choice? The accel systems was mentioned in the earlier posts, how are they as far as learning to tune i see them quite a bit used on here and ebay. Taxes are almost in and i wanted to get a new system before i get transfered to Cali but wanted to be sure i get the right one for myself. I really appreciate all the help and advice everyone is giving, its sometimes hard to reply back the same day as the military keeps me busy, thanks again for all the help.
Imo the Accel is very easy to tune, just press F1 on any screen you're on and a help screen comes up and it can be tailored to almost any application.
I would suggest downloading the software and looking at it from there, that'll tell you a lot.
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
If you're seriously considering an aftermarket system you should look at Haltech's Sport GM.
It's specifically made for austrailian cars that run a slightly different version of your factory ECM and thus it's basically plug and play.
Car: 87 GTA
All the reserach ive done on all the systems, they all replace my maf with a map sensor correct?
Yes!
Do you have to register your car in Cali and pass their emmisons tests? Any mod has to have a CARB number and still pass emmision tests. Even if it passes tests emmision tests it could fail for changing a part to one without CARB number. It has been a few years since I had to deal with that but was not fun, hassle after hassle, and hassle would change when inspector changed... passed for this on one inspector, then failed with this on another inspector, back and forth... glad I don't live there anymore...
I am as to why MegaSquirt was not mentioned once here. I have run the first two editions and have been happy with them. I'll be ordering MSIII soon and the connector/adapter from diyefi and it just plugs into the stock harness. It's not self learning, but you can use this for ANY fuel injected engine. MSIII will even put datalogs on a sd card, no laptop required. Why is there no love here???
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
I did chip burning at the begining then i started Megasquirt + adaptor board for TPI + TuneStudioMS (with full licence) + WBO2 does selftune if You give starting point map on VE. I run this setup and i'm more then happy with it. And please do remember: even if any of mentioned here does selftune You still have to control what it do and check it every once awhile, AFR gauge is a good idea too. Selftune is just a help for quicker tune not to do all the job!
Best regards
Best regards
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
MSD's Atomic EFI looks like it match RBobs system. Fuel & Spark timing up to 600hp plus fan & A/C controls (covers everything I want). Been reading up on the MSD system and they really break it down simple for you. The big draw back to the MSD system over the EBL is that the entire system in integrated into the Throttle Body and no emissions controls. Great for packaging, but a horror to work on if anything in the system goes out.
#42
#43
http://www.dynamicefi.com/ is the answer! Period.
#47
#48
Car: 2003 F-150
Transmission: 4R70W
A distributor with a magnetic trigger and the advances locked out such as the MSD 80551
An ignition box such as the MSD 6AL
Pricy, yes. Easy as pie to do, heck yes. Best of all, no laptop. Just use the handheld as needed.
#49
They sure don't. Unlike any other EFI system out there, they spell it out in GIANT BOLD LETTERS and COLOR SCHEMATICS in the standard product literature what you need to do ECM controlled timing with the Atomic EFI system:
Yes it will do spark, my bad, but it's limited and doesn't allow for temp changes, keeps the same timing amount no matter what, that's a huge disadvantage, especially on larger cammed applications.
You gotta send in the unit if the MAP, IAC or regulator goes out? How inconvenient is that?
It won't automaticlaly change for altitudes if it's not in a certain load and rpm range, you have to cycle the key, TRY THAT WHILE DRIVING DOWN A MOUNTAIN!
No laptop, for some that's a plus. But it also means less tables/less tunability, period.
Can't change injector size - for a smaller/less hp motor that would be beneficial, always use the smallest injector you can with the most pressure, it'll drive better, can't do that on this unit.
Do you want me to go on?
Why not spend another $300.00 and get something that does everything listed above and more.
Jmo.
#50
Car: 2003 F-150
Transmission: 4R70W
After I wired my second engine harness, I decided that a plug & play system with minimal splicing was all I could stomach doing again. MSD spells it out clearly what this system can and cannot do and how it can be made to work for XYZ application. Amazing what a little reading will do for purchasing decisions.
