Changing EST
Old Feb 18, 2012 | 10:11 PM
dposey's Avatar
Changing EST
Thought one of you guys might be able to help but if this is inappropriate I am sorry. Installed GM TBI on an older four cylinder engine and discovered the distributor rotates opposite direction as the GM 2.5 engine. Needless to say I have allot of retard and no advance. I have been running engine with bypass unhooked. Any hints would help because 0 is the least that T Pro will allow in the main spark table. Using the 165 ECM with $94 mask 91 S-10
Old Feb 18, 2012 | 10:20 PM
EagleMark's Avatar
Re: Changing EST
What did you use for distributor? Or did you do a duraspark pickup to external mounted EST? Wires are backwards...
Old Feb 19, 2012 | 07:19 AM
dposey's Avatar
Re: Changing EST
I machined the 1991 GM 2.5 distributor to fit in the older engine. This is an eight pin distributor.
Old Feb 19, 2012 | 08:46 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Changing EST
Swap the two wires from the pickup coil to the ICM. IOW, reverse the terminals they are on going to the ICM.
RBob.
Old Feb 19, 2012 | 09:27 PM
dposey's Avatar
Re: Changing EST
That change corrected the advance problem. THANK YOU
I did need to adjust the base timing a substantial amount after changing the wires. Is that normal?
Old Feb 19, 2012 | 10:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Changing EST
Yes, that is OK.
RBob.
IROCtometal
Sep 20, 2015 11:08 PM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
