Jet Performance Chip Problems???
Old Feb 18, 2012 | 11:24 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
Today I recieved a Jet Performance chip I ordered for my 88 305 TBI Camaro Base model with an automatic transmission. I installed it but when I started it the RPM were extreemly high at idle and my check engine light flickered like a stroble Light. I drove the car and I didn't notice much different in power. Obviously something is wrong but can somebody help me figure out why It's doing that?? I asked a guy I know and he said maybe turn the idle down a bit on the throttle body stopper to reduce the idle... he also said it could be why the MIL light is flickering, becuse the high rpm (2000) at idle and almost wanting to do a burn out in drive. I made sure when I ordered the chip, I gave all the right info.. Also the flickering MIL light comes on as soon as i turn the key to the run position. I was able to take it out and put the stock one in no problem but liike I said i just need some help at why It could be like that. the help is much appreciated!
Old Feb 19, 2012 | 12:42 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Re: Jet Performance Chip Problems???
Are you sure you put the chip in the right direction.
Old Feb 19, 2012 | 08:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is either as dave posted or it isn't the correct chip. The '88 f-body ECM is a one year only. So if the chip is for a '89 -'92 f-body TBI it won't work.
The fast flickering SES is due to a checksum error of the EPROM contents. The ECM is in limp mode.
RBob.
Old Feb 19, 2012 | 09:19 AM
Thanks guys, Like I said... I ordered it online and I gave all the info of my car so i'm not sure if they gave me the right one. And I'm pretty sure It was facing the right direction
Infested
May 22, 2018 11:56 PM
fasteddi
Sep 2, 2015 10:29 AM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
