ECM 1226865
Old Mar 12, 2012 | 09:04 PM
Sonny_T's Avatar
Car: Transam, 85
Engine: 305 HO, 4bbl Carb, G Engine
Transmission: 5 Speed
ECM 1226865
Car is 85, Transam, 305 HO, 4bbl carburator, G code.
ECM is 1226865. Need to know:
1. Am I correct when I say my ECM has EPROM and not MEMCAL?
2. Is there any special tool to remove memory from ECM.
3. It appears that there are two pieces in memory slot. Do I remove the right one only?
4. Rockauto sells 1226865, but it doesn't show having any memory. Site doesn't have any memory for 1226865, where and what kind of memory do I buy.
5. Do I have to reprogram this memory.
Thanks.
Old Mar 13, 2012 | 01:26 PM
EagleMark's Avatar
Re: ECM 1226865
Looks like a C3 ecm? I've never worked on CCC ecm but if it has 2 chips the big one will be the one that runs the engine and the little one is called a Netres and is the limp home chip. Usually replacement ECM do not come with either.
Old Mar 13, 2012 | 06:44 PM
Sonny_T's Avatar
Car: Transam, 85
Re: ECM 1226865
Thanks EagleMark.
What is a C3 ECM? Where can I buy this memory?
Old Mar 13, 2012 | 07:11 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM 1226865
disconnect the battery, remove the ecm, remove the eprom access cover, remove your eprom and calpak and install into the new ecm. install the access cover, install the ecm. reconnect the battery . Done !
Old Mar 13, 2012 | 07:41 PM
Sonny_T's Avatar
Car: Transam, 85
Re: ECM 1226865
tunedperformance' thanks.
Do I need any special tool to remove memory, or do I use a flat screw drive to pull it out.
Old Mar 13, 2012 | 09:04 PM
EagleMark's Avatar
Re: ECM 1226865
You can use a screw driver but normally your fingers will work. They just come straight out.
Old Mar 14, 2012 | 05:32 PM
Sonny_T's Avatar
Car: Transam, 85
Re: ECM 1226865
'Eaglemark' & all thanks.
In case if I need to replace eprom any one would know eprom part number. What I kind of reader/burner will read this eprom.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
