ADS SUPERCHIP
Old Mar 18, 2012 | 03:28 PM
Apache truck's Avatar
ADS SUPERCHIP
I have -88 TPI engine which I`m going to install to my -58 Chevy truck. When I inspect the ECM I found that someone had allready installed the Ads Superchip type 8820-A inside.
I tried to find information of this chip from internet but no luck.
I only found out that there are A,B and C types of this chip.
What is the difference between normal chip and this ADS chip?
I donīt have the steering column from that car where I got the engine so I will probably have problems with that VATS system (that should be in 1988 model GTA)?
I have Painless Wire harness -- in the instruction book they tell that there are some aftermarket chips which are without the VATS --- is this 8820-A chip like that?
Thanks!
Old Mar 18, 2012 | 08:20 PM
EagleMark's Avatar
Re: ADS SUPERCHIP
I found one on eBay and it said stage 1. I found a stage 1 HT chip in a JY ECM once and compared it to a stock chip and it had several differences, none of which amounted to anything other then they should be arrested for fraud of claiming it would do anything more then a stock chip.
If it does have VATS enabled there is a kit for like $15 on eBay I saw awhile back that gets wired into ECM harness to satisfy the ECM and lets fueling proceed. On a car it disables fuel and starter when VATs module is in place which you wouldn't use in a conversion.
Old Nov 1, 2012 | 10:31 AM
oddscrounger's Avatar
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
Re: ADS SUPERCHIP
I also have an ADS superchip in my ECM... I am the third owner and I found the original box this chip came in with all the crap the previous owner gave me. Looks like this was purchased back in '87 or shortly thereafter... not a good chip? I know nothing about it. I have the original chip too...
Ed1LE
Sep 30, 2018 09:14 AM
86IROC112
Nov 7, 2015 06:50 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
