Fuel pressure effect on o2 voltage?
Old Jun 13, 2012 | 08:57 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Someone correct me if i am wrong here. If i lower my fuel pressure then i should expect o2 voltage to drop a little? along with my BLM rising. If IIRC, richer (more fuel in the mixture) should lower the amount of oxygen in the mixture as it passes by the o2 sensor. My goal here is to lower my o2 voltage at WOT from .920 to about .850 or less. I should be able to just lower my fuel pressure to acheive this right? ...............and no, i dont wanna use a wideband or play with my VE table.
Old Jun 14, 2012 | 06:36 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Fuel pressure effect on o2 voltage?
it's not a great method of doing so, but yes, lower pressure = less flow.
not sure how much the fuel trims will effect it though.
Old Jun 14, 2012 | 08:09 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
A .920 to .850 (or less) decrease in fuel is a pretty substantial drop. How are you planning on lowering your fuel pressure that significantly, with just an adjustable fuel regulator? Why is your wide open throttle fueling that rich to begin with? If your going to avoid using a WB and/or playing with the VE table, then I wouldn't bother lowering my pressure to get the fueling down, I would simply go with the very next sized down fuel injectors...
Old Jun 14, 2012 | 09:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
And the rising BLM (above 128) will be used during WOT and the O2 will be back to where it was before.
RBob.
KCG
Jun 24, 2020 04:33 AM
MM2Robinson
Oct 1, 2017 09:16 AM
eustodp
Sep 20, 2015 05:09 PM
ULTM8Z
Sep 16, 2015 09:15 AM
RyanJB
Sep 2, 2015 01:27 PM
