ecm data log
Old Sep 6, 2012 | 08:43 PM
strocker383's Avatar
ecm data log
im new to tbi ...im looking for a program that i can buy or get free to change things into the ecm ...if someone can help me about it i would appreciated ..im new into it ...try to see if its easy to do it by my own ..i got a aldl connector and a laptop ...what i need to buy now
Old Sep 7, 2012 | 08:08 AM
Re: ecm data log
can u change value with the winaldl i didnt try it yet ????
Old Sep 7, 2012 | 10:03 AM
armos's Avatar
Re: ecm data log
You can use TunerPro to make a modified .bin file. Then you need to burn it onto a chip. You can do that with an EPROM programmer.
For a starting point you would want to dump the contents of your factory chip, or find the correct file for your car online. You would also need a "definition" file for TunerPro that matches your ECM. This is what allows it to understand the meaning of all the values in the chip.
Some people have a modified setup that uses EEPROMs and can be reprogrammed in the car. I don't know how that setup is put together.
Old Sep 7, 2012 | 12:50 PM
Re: ecm data log
im really a newbie at it ...can u point me into direction of things i need to buy ...can u erase and burn many time ??
Old Sep 7, 2012 | 02:30 PM
Ronny's Avatar
Re: ecm data log
Go to craig Moates website. they have a low cost product to burn a chip. EEProms are what you want to use.
Old Sep 7, 2012 | 11:11 PM
armos's Avatar
Re: ecm data log
EPROM and EEPROMs can both be erased and reused. I use EPROMs with an old parallel port programmer that was made in the 90s. EPROMs also require a UV eraser to erase them (they are erased by exposure to ultraviolet light).
EEPROMs can be erased electronically, so they don't need a separate eraser and they're more convenient to work with.
Most of the people on this site appear to use EEPROMs with some kind of Moates setup, as the previous poster alluded to. Since that's what most people here are using, it's probably the safest way to go for help/support.
I haven't had experience with Moates myself so I can't tell you exactly what parts you should buy, but there should be others who will know.
The TunerPro software has a free version available.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
bjpotter
Oct 4, 2015 07:48 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
