Tuner Near Toronto?
Old Sep 8, 2012 | 11:32 PM
Mapleleafs98's Avatar
Tuner Near Toronto?
Hi everyone, I have been going nuts with my car. I have an 86 CAMARO that had a stock 305 tpi and was auto. I now have a 350 ZZ4 crate motor with a tpis mini with 30lb injectors, with a tremic tko 5 speed. With the stock chip it runs ok but really rich but the car doesn't run to bad in open or closed loop.
I have tried someone programming a custom chip and when the car goes in closed loop, it runs amazing and a lot stronger, the problem is that in open loop the car runs horrible and bogs out and seems like it is getting flooded. I was wondering if anyone has a bin file that I can try as I have the programmer to burn the moates chip. If anyone has a tpis mini with 30lb injectors set up on a 350, I would love to try a bin that might work on my car or at least get me started. If not, does anyone know of a tuning shop or a tuner that will do my car in the Toronto area?
Thank you very much for reading.
Old Sep 8, 2012 | 11:36 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: Tuner Near Toronto?
If I was home, I used to have a 350 on a miniram and 32's and it ran great. Were you running the 7730 ecm or the 7165 or 7749 ecm and was it a Map or Maf Sensor.. Makes all the difference in the world. I won't be home until the end of this month
Old Sep 8, 2012 | 11:48 PM
The computer is a 16198259 which is equivalent to the 165. It is a MAF system.
What system did u have and what kind of injectors and what ECM?
Thanks.
tmellott89
Oct 14, 2015 02:06 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
R13_Braz
Sep 18, 2015 05:00 PM
rubyred88
Sep 17, 2015 02:19 PM
85Special
Sep 3, 2015 04:21 PM
