Tunerpro display bunched up at bottom
Could not get EFILive to run, so i tried tunerpro. 1987 IROC 5.7TPI autl 165 eprom.
installed tunerpro. could not get it to connect either. Finally used
aryap and $6e. on 160 baud with the jumper on 10k on cable. And tuner pro started running! Soooo, 2 questions!
1/ How do i get tuner pro to open up the display windows/graphs/dashboard? I've tried changing cascade, tiling, you name it. They all hunch up at the bottom of the display so i cannot read anything. Not exactly what you want going down the road.
2/ the car runs REALLY crappy with the jumper in place. The CEL is flashing and the idle is hunting and the fan is on. Am I gonna be able to DRIVE it this way?
Car: 64 Studebaker Avanti,67 ElCaminoTBI
Engine: GM 350 10.5:1 Supercharged
Axle/Gears: 3.54 posi
Re: Tunerpro display bunched up at bottom
my El Camino won't run correct when hook to scan tool, Try removing the program and down loading again.
Transmission: 5-speed/T-5
Grab the edge of the dashboard with the mouse/cursor, then pull up to expand the dashboard.
You can also "undock" the dashboard and run it full screen (or on another screen) if you wish. I believe the F8 button is used for that, but would need to verify.
I haven't used $6E, but it has been said that you can switch the 10K resistor off after a connection has been established.
Hi six shooter - i have tried grabbing the screen. No dice. It only has an x box, it doesn't have a make smaller/make bigger. I tried running it full screen too, nope, its still all bunched up at the bottom of the tunerpro. Its really weird cause it started that way the 1st time
i had to restart the computer, and then it would let me open the window up by stretching. For our cars, are there only 6 gauges on the dashboard? I've got a going lean problem (i think) that i'm trying to hunt down. I do like the page with the counters, I can see the knock sensor counts, etc.
The default dash is usually 6 items, but the dashes are configurable, and have seen upwards of about 30 parameters displayed on one dash.
MrPackstin
Oct 25, 2017 08:09 PM
