ECM question.
Old Oct 21, 2012 | 06:24 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
ECM question.
When is it necessary to swap an ECM after mods?
For example, say I have a 305 TPI now. Then I put in a 350 TPI. Would it be necessary to swap in a different ECM or just the PROM?
Or say someone put in a 383 to replace their 305 or 350. Would they need to replace their ECM, the PROM. Or just keep it all and reprogram?
Old Oct 22, 2012 | 08:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ECM question.
Regarding your '90, going from a stock 305 to a stock 350 (including injectors), you could likely get away with the 305 PROM. It would be best to swap in a 350 PROM. Note that you wouldn't want to swap just the PROM, but the entire MEMCAL. As it also contains the knock filter (ESC module).
Now going to a 383 is a bit different. usually because there are other upgrades done at the same time. Such as heads, cam, and larger injectors. If the stock heads and cam are used, along with 24#/hr injectors, most likely could get away with a stock PROM.
But all in all, it will be better with some tuning. Even stock engines can be tuned for better performance.
RBob.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
