Some PROM questions
Old Nov 8, 2012 | 02:14 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
Some PROM questions
I have a mail order tune on it's way, it is on a piggyback adapter so I need a stock PROM. My car is an '85 Corvette but I upgraded the ecm to the 165 version. Here are my questions,,
1. Can I buy any stock prom as long as it is for the 165 ecm?
2. Can I use a Camaro/Firebird PROM or does it have to be Corvette?
3. Does it have to be for an automatic trans.?
Thanks for any help you can offer.
Old Nov 8, 2012 | 02:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Some PROM questions
if you have a piggyback tune on it's way for the 165 you just need a tpi maf memcal from 86-89 and it will not matter what the calibration is because you are just using the 16055375 and 16055376 for i/o and lhm. You will need to have you fan setting change too n/o I believ or the cooing fans will run all the time.
Old Nov 8, 2012 | 02:26 PM
Engine: Lb9
Transmission: M20
you can always use a 3.1 or 2.8 memcal from a 1227730 and jumper 56 to 62 on the memcal.
Old Nov 8, 2012 | 02:50 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
Thanks, I appreciate your help.
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
