Stock prom questions....
Old Mar 29, 2013 | 12:17 AM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Are the stock "chips" programmed to provide more fuel during a clod start (1989 5.7 GTA) than when warmed up? I am suspecting I might have bad injectors, but before I drop a bill I am trying to make good sense of this aspect of the program inside the "chip." Thanks
Secondly, would you need to reprogram for 24lb. injectors? I would think they would be fine as 22lb replacements, but....
Old Mar 29, 2013 | 12:27 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Stock prom questions....
The 89 $6e mask tunes have cold start enrichment up to 240f as well as idle rpm vs coolant temperature.If your injectors look like these toss them as fast as you can. If the eprom has not been reprogramed for a larger injector stick with a 22#hr or tune accordingly.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
Keith5
Aug 27, 2015 04:37 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
