CEL won't turn on
Old Apr 13, 2013 | 08:12 PM
love shack's Avatar
Car: 1984 Trans Am
Transmission: 5-speed
CEL won't turn on
Hello,
I did some searching and couldn't find much on this, but I apologize if this is an easy one. I have an 84 T/A 5-speed, stock.
My check engine light won't come on at all, not at start and not if I put in a jumper for the diagnostic test. The ECM fuse is ok. I pulled the gauge cluster and the light bulb is not burned out. I've pulled out the ECM and all the wiring looks to be in good shape - nothing obviously loose.
What else should I check? Even if the ECM was toast, I should still get some flashing of the CEL when I put in the jumper, should I not? I appreciate any advice!
Thanks in advance,
Steve
Old Apr 13, 2013 | 09:47 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: CEL won't turn on
How did you test the bulb? If bulb test good and acually lights, then maybe its the wireing to the bulb.
Old Apr 14, 2013 | 06:46 AM
love shack's Avatar
Car: 1984 Trans Am
Thanks - I just visually checked the bulb but I will replace it just in case. I have a couple other burned out dash bulbs anyway.
When I said I checked the ECM fuse, that was just the one under the dash and after searching some more, I realized there is apparently an inline fuse for the ECM under the hood on the passenger side? Now I just need to find it...hopefully it's as simple as that.
Steve
Old Apr 14, 2013 | 08:14 AM
red rock's Avatar
Car: 1987 iroc
Steve
Does the car run Ok? Or is it just the light not working.
Old Apr 14, 2013 | 09:29 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
This sounds like you need to take a look at the lamp driver 12020004 acdelco 216-51. Refer to a fsm for a schematic .
Prodigious
Nov 7, 2020 09:23 AM
Derick15
Sep 17, 2016 05:28 PM
WIzmo
Aug 30, 2015 02:30 PM
ZsTransAm
Aug 11, 2015 07:30 PM
BrianI
Aug 9, 2015 11:52 AM
