How to remove chip?
Old May 2, 2013 | 11:26 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
How to remove chip?
I just got a new aftermarket chip to bypass VATS and went to go take out the stock one but it doesn't come out! I've tried prying underneath the chip but it's pulling out the terminals so I don't want to damage anything. Is there a proper way to remove this? thanks
Old May 2, 2013 | 11:34 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: How to remove chip?
The stop EPROM is soldered in.
The best way is to get an adapter that will allow the LHM and Knock filter of the original MEMCAL to be retained and allow the new E/EPROM to be placed in such a way that the ECM reads it.
Moates.net is one such place that sells the adapter. Look at the G1.
Old May 5, 2013 | 12:41 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Its easy to unsolder the stock eprom nd solder in a d2 dip. You just about destroyed that memcal.
Old May 5, 2013 | 12:54 AM
Axle/Gears: 3.45
I know, I realized too late that it can be easily unsoldered. Does it look too damaged to function from the pic? I'm not sure how sensitive these things are and the bypass chip doesn't seem to be doing a whole lot. This is the issue I'm stuck with and I'm trying to determine if it's VATS related
https://www.thirdgen.org/forums/tech...ml#post5553946
Old May 5, 2013 | 12:57 AM
Engine: Lb9
Transmission: M20
The no legs are broken on the eprom so it should still function properly, I tried to load the video and nothing happens.
Old May 5, 2013 | 12:59 AM
Axle/Gears: 3.45
Okay I'll try an upload it to another host site. Should be up in a few minutes
Old May 5, 2013 | 01:06 AM
Axle/Gears: 3.45
New links are up on original thread
Old May 5, 2013 | 12:39 PM
Engine: Lb9
Transmission: M20
I will install a dip and reprogram for this months vats disable special if thats of any interest.
https://www.thirdgen.org/forums/spon...ial-month.html
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
RyanJB
Sep 2, 2015 01:27 PM
