emc
emc
I need help i have a 1988 chevy caprice with a quadrajet electonic carb my problem is thati when i disconnect the mixture control solenoide car runs but onece i plug it back car dies right away i checked the solenoide plunger travel and its right also the solenoide makes the clicking noise when switch is on any ideas how to fix the problem thank you
Car: check
Engine: check
Transmission: check
Re: emc
Not sure how much folks here know about the E carb set ups. Most tend to remove them and go non-E. Back a few years when I was working on one, I found info on various sites all over the 'net.
Basically, a little here and a little there. It was helpful in getting to understand these E-carbs. Check the carb board here too, there may be some useful information.
RBob.
RBob.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: emc
Originally Posted by carlos83
I need help i have a 1988 chevy caprice with a quadrajet electonic carb my problem is thati when i disconnect the mixture control solenoide car runs but onece i plug it back car dies right away i checked the solenoide plunger travel and its right also the solenoide makes the clicking noise when switch is on any ideas how to fix the problem thank you...
Replace it...
