Vats Question
Car: 1992 Firebird
Engine: 3.1 L V6
Transmission: Automatic
Vats Question
If i put the resistor into the wiring and then try my key with the bullet resistor still in the key. Will it work or will it read too much resistance?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Vats Question
With two resisters in series the resistance would be to high for the pass key module to operate. If your wanting to permanently disable the vats I am running a special this month to reprogram out the vats in the memcal for $35 or I have complete memcals for a little more pm me if you are interested in that option.
