A/C Help
Old May 28, 2013 | 04:42 PM
beast94's Avatar
Car: 1994 Chevy K1500
Engine: 355ci, TBI with vortec heads
A/C Help
Hello,
I have been working to figure out why EBL does not recognize that the A/C was turned on. I have in the mean time lowered the turn on temp for my electric fan in order to cool the condenser.
I looked up the wiring diagram for it and sure enough neither the A2 nor B8 socket has a pin in it. I then found my "re-pin" list from the install and it says to move E12 to B8, but there is no E12 pin in my OEM harness and I do not have any loose wires. I am kind of out of ideas for where to go now. The vehicle is a '94 Chevy K1500. Thanks
Chris
Old May 28, 2013 | 05:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: A/C Help
Originally Posted by beast94
Hello,
Chris
Not sure why, but E12 of the original harness should have had a dark green wire to it. It is a signal directly from the A/C compressor clutch. If one doesn't exist can add one. This will tell the EBL ECM to know when the A/C compressor clutch is engaged.
RBob.
Old May 28, 2013 | 05:35 PM
beast94's Avatar
Re: A/C Help
Ok, Im guessing I can just splice into the existing wire off the compressor and run it to B8. Is there anything else I may need to do? What about A2? Thanks Bob
Old May 29, 2013 | 07:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: A/C Help
For the ECM to be aware that the A/C is on, that is all you need to do. Run a wire from the clutch wire to ECM pin B8.
If you also want the ECM to control the A/C compressor, additional wiring and a relay is required. There is a wiring diagram of how to do this on our web site.
RBob.
Old May 29, 2013 | 07:19 PM
beast94's Avatar
Re: A/C Help
Thanks Bob, I will get that wire run to the computer.
Old Jun 18, 2013 | 07:02 PM
beast94's Avatar
Re: A/C Help
Bob,
I know you said that the ECM can control the compressor with a relay, but I have also been wondering if the ecm can control the fans when the A/C is turned on. I would like to add an fan and have it only turn on when the A/C is turned on. Is this possible to do with the EBL?
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
