305 Knock Sensor - TPI Swap
Car: 1992 RS, 2000 Z28
Engine: LO3 with TPI Swap, LS1
Transmission: 700-R4, 4L60E
Axle/Gears: 3.42 with TruTrac LSD
I'm on the tail end of completing my TBI to TPI swap. I'm currently getting SES Code 43 (knock sensor).
I ended up using the original TBI knock sensor since I had looked up if the sensors were different and the info I found at the time had said that they were not. Now that I'm getting an SES code I looked it up again and the part numbers are different for a 305 TBI sensor and a 305 TPI sensor (which is what I should have done to begin with!).
Does anyone know if these knock sensors are interchangeable between the TBI and TPI? I'd rather know that it is, in fact, different before I pull the knock sensor out and flood my nicely redone engine bay with coolant.
Thanks in advance for the info!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 Knock Sensor - TPI Swap
It's located correctly, it will still flood areas of the engine bay that I would prefer to not get flooded.... this is a show car. But i will do what I have to do. The bigger question is, are the knock sensors interchangeable between 305 TBI's and 305 TPI's?
Engine: Lb9
Transmission: M20
In tpi maf tbi L03 and LB9 gm10456287 ac delco 213-325
http://parts-catalog.acdelco.com/cat...701&parttype=0
Engine: Lb9
Transmission: M20
ESC numbers
16126761 (ANRZ) is discontinued. Replaced with HKR for the 4.3l & 5.7L engines, and HKM for the 5.0l engines.
16022621 (BLH), is for 2.8l, 5.0l, and 5.7l engines.
http://chevythunder.com/maf_esc_module_code_43.htm
ESC numbers
Car: check
Engine: check
Transmission: check
The knock sensors are different between TBI and the '90 - '92 TPI engines. Has to do with the resistance of the sensor that is required for the '7730 $8D malfunction testing of the ESC system.
That is why code 43 is being set. When you get a new knock sensor check the resistance between the terminal and body of the sensor. It should be in the 3.9K ohms (3900) area. If not then they gave you the wrong sensor. Better to check it before then after being installed...
RBob.
RBob.
Engine: Lb9
Transmission: M20
As Rbob stated the ohms resistance is 3.9k on this sensor.
Acdelco 213-96 GM 10456126, 15762437
Sanjay
Aug 12, 2015 03:41 PM
